I have a code P1120. It apparently means that the TPS is out of range. I changed the TPS. The symptoms the car has is that it revs itself whenever moving, up to about 3k. If you are standing still, it idles normally. TPS voltage is flutuating, I'm getting between .8 and 1.1 at idle, its different everytime you start it. It tends to work fine if you start it cold, drive it, turn it off, then start it warm. After its started warm, the car no longer revs. Any ideas?
Car is a 98, 2.5, 5spd.
1998 Contour SE 2.5L Duratec DOHC 5spd. "Who needs a working IMRC? - I don't." 1968 Chevelle 300 Deluxe 1994 GMC Yukon SLE 1972 Plymouth Roadrunner - restoring for a friend.
