#1573809 05/19/06 11:22 PM
Moloko Offline OP
I have a code P1120. It apparently means that the TPS is out of range. I changed the TPS. The symptoms the car has is that it revs itself whenever moving, up to about 3k. If you are standing still, it idles normally. TPS voltage is flutuating, I'm getting between .8 and 1.1 at idle, its different everytime you start it. It tends to work fine if you start it cold, drive it, turn it off, then start it warm. After its started warm, the car no longer revs. Any ideas?
1998 Contour SE 2.5L Duratec DOHC 5spd. "Who needs a working IMRC? - I don't." 1968 Chevelle 300 Deluxe 1994 GMC Yukon SLE 1972 Plymouth Roadrunner - restoring for a friend.
#1573810 05/20/06 02:02 AM
Check for voltage between the battery negative terminal and the "low" (REF) wire of the TPS. I'd be suspecting a faulty ground/return circuit.
Steve
#1573811 05/20/06 02:32 AM
I don't know if this would help but on my buick I got a trouble code telling me I had a bad tps and it ended up being a bad maf (mas air flow).
#1573812 05/20/06 08:50 PM
Those are the symptoms my car was exhibiting before I sold it. The TH fix solved the high rev for me but it wasn't a permanant fix. If you come to a solution I would be interested in hearing what you did. My problem was that every once in a blue moon it would throw a P0122 (TPS low input) code.
Then: 99 Silver Frost SVT #1919 237hp/219tq All Motor Now: 06 White STI Parts 4 sale
