#117359 04/17/02 05:23 PM
I will be in the process of swapping out my non SVT engine for a 1999 SVT engine. I have a few questions on the MAF and TB.
1. Can I use my old TB/MAF assembly and KKM from my non-svt engine?
2. If I do that, I would think it would run rich, right? Can I simply change the MAF to a standard SVT one, using my old TB and KKM?
3. Would I need to buy an SVT KKM? why else would they sell an svt version I'm thinking.
4. What about the computer? I can't use an SVT one due to the PATS system, so I would have to go with a Superchip or diablo. To do that, I would need to find out the original computer code from that engine right to give to either diablo or superchip?
Sorry if any of these qestions seem stupid, I just want to get all my ducks in a row before I go ahead with the swap.
Thanks. Simon.
Simon W. Las Vegas.
96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!)
1999 SVT Engine
SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT
"it's only nuts and bolts" - Terry Haines
"Drive it like you stole it" - Me!
#117360 04/18/02 06:30 PM
What you need to do is go get an MAF from pro-m or granetelli that is set for 19lb. injectors. Otherwise, you will hate the way the car runs with the stock MAF set for 16lb. injectors. Using a stock SVT MAF will work, and so will your KKM and thottle body, although they might require a little modification.
Paul Woodward
95 SE V6 MTX
KKM, 8mm plug wires, no badges, 75HP shot of THE JUICE, B&M T-Handle Shift Knob, MOMO Aluminum Pedals, Richbrooke e-brake handle, A-Pillar with Phantom air-fuel ratio gauge, voltmeter, and oil pressure gauge, Unorthodox Racing Pulley, In dash 5" TV screen, playstation one, Apex DVD player, Digital TV tuner. Coming soon, Sho-shop y pipe and 2.5 inch single pipe exhaust
Dyslexic man sells soul to Santa... Film at 11
