lizard Offline OP
ok i have codes P0171 and P0174 which says bank 1 and 2 and running lean how can i fix this?
and P1400 which is Differential Pressure Feedback Electronic Sensor circuit Low Voltage how can i fix this?
thanks for the help
2000 contour V6 ATX BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
#1572750 05/17/06 01:21 AM
The DPFE code (P1400) could be related to the lean codes (P0171 and P0174 massive vacuum leak). I would suggest checking/changing the DPFE sensor first to see if it solves the problems.
Originally posted by chongo:
Did someone call me out.......LOL
here you go.
Also see Fig 1.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/ca/1e/0900823d801bca1e.jsp
#1572751 05/17/06 03:54 AM
lizard Offline OP
thank you
