I concur -- very very probably 'dirt' on the MAF.
I have a K+N on my 97 SE V6 and twice a year clean the filter and MAF.
Only the 'lightest' of 'layers' of oil is needed on the K+N filter to keep it 'good'.
After a week or so - after cleaning and oiling the K+N - I take it off and then - using 'electrical switch cleaner' - I give the two 'filaments' of the MAF a good soaking. (Put a wad of Kleenex UNDER the 'venturi tube' to soak up excess.)
I wait a week because I'm figuring any 'excess' of oil, on the K+N, will have already dissipated down the throttle body. Thus, it makes little or no sense to clean the MAF immediately after re-oiling a K+N.
Don't be tempted to stick a cotton bud into the venturi to 'super clean' the MAF filaments. They are VERY easily broken. Just soak the living daylights out of them with fluid.
After doing all of this I disconnect fuses/relays '9' and '11' which removes all power to the ECM and ECM memory -- thus allowing the car to 'learn all over again'.
So far, going on 9 years now, have not had an iota of a prob.
Gerry
