#1570847 05/13/06 11:11 PM
ok i am getting p0153,1405,1518. i know what 1518 is. 0153 says it is a up stream o2 bank 2 i think. 1405 dpfe upstream hose. what does that mean? i am guessing i will have to replae the o2 then.
G/f's black 99se sport 5 speed 2 1/2 test pipe-custom cat back 3 single tip cai with kn3530 safc optimized tb 8mm plug wires spec stage 1 clutch svt front bumper
#1570848 05/14/06 02:03 AM
P1405 Check to make sure it did not come loose. It goes from the bottom most connection of the EGR tube to the DPFE sensor. Note bottom most is upstream as the stream of exhaust is going up (so the top connection is considered downstream).
Originally posted by chongo:
Did someone call me out.......LOL
here you go.
Also see Fig 1.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1b/ca/1e/0900823d801bca1e.jsp
P0153 Yeah, maybe time for a new Bank 2 Upper O2 sensor.
Bank 2 (radiator side) Upper O2 sensor;
On this 2-Dimensional picture, ignore the red box and arrow, the Bank 2 Upper is the sensor on the left of the pre-cat (closest to the oil filter). The arrow is pointing to the Bank 2 pre-cat
From TSB,
P0153 - HO2S Sensor Circuit Slow Response Bank 2 (Radiator side) Upper O2 sensor (HO2S-21) The HO2S monitor checks the HO2S sensor frequency and amplitude. If during testing, the frequency and amplitude were to fall below a calibrated limit, the code will set.
Electrical:
�· Shorted/open wiring
�· PCM
Induction System:
�· MAF sensor (On 4-cylinder engines, if P0133 is present, this could be caused by a MAF issue - on 6- and 8-cylinder engines, this could only be a MAF issue if P0133 and P0153 are both present)
�· Inlet air leaks (unmetered air)
Fuel Concerns:
�· Poor fuel quality
Base Engine:
�· Exhaust leaks (upstream or near HO2S)
HO2S Concerns:
�· Contaminated HO2S sensor (contamination from the use of silicone-based cleaners and sealants, leaded fuel, excessive oil consumption, etc.)
�· Deteriorating HO2S sensor
