Posts: 41 |
I have a 98 SE, 2.0L ATX, My right front tire on occasion sounds like I have a snow tire on the thing. I have had it alligned and tire wear seems normal. No pulling or other rattles. Anyone have an idea what I should look at? I have done the bearing check and that seems fine. I'm stumpted.
-sp
Posts: 5,345 |
Originally posted by sprindl: ... My right front tire on occasion sounds like I have a snow tire on the thing. ..
What are the occasions? Turning? Low speed or high speed? Could be bearings, brakes, cv joints.
1996 V6 ATX 96K miles
Posts: 41 |
Straight driving. That's why it seemed odd.
-sp
Posts: 6,910 |
could be a bearing anyway, when I had one go I could hear it when driving straight and then as it got worse you would hear it in a turn
- 95 Mystique LS - Zetec/5spd
Posts: 41 |
Are the wheel bearings a Ford only part? Or can a get them somehwere else. I'm haveing my rotors surfaced next week so I'l like to get them changed then as well.
-sp
Posts: 4,693 |
It could also be cupped tires.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 320 |
i had the same noise last week. when the car was going straight the noise was worse. when i went around a right hand turn the noise got better and worse around a left hand turn. advance auto parts had the bearings for $27 a side and ntb put them in for $120. what a difference! now i can turn my stereo back down.  i also had the transmission fluid changed as well as the front brakes and rotors(i changed the brakes and rotors myself because people get ripped off for these!!!!)
2006 fusion sel
1998 grand prix gtp(wife)
1993 dodge shadow es(winter beater)
Posts: 463 |
Before you spend money on any parts rotate the tires front to back and see if the noise follows the tires or stays in the same place. I had what sounded exactly like a bad wheel bearing turn out to be a bad tire.
jeff
have you fixed your ford lately?
Posts: 103 |
Originally posted by mercman: Before you spend money on any parts rotate the tires front to back and see if the noise follows the tires or stays in the same place. I had what sounded exactly like a bad wheel bearing turn out to be a bad tire.
jeff
Good advice. I'm going to get my FR bearing replaced this week for similar symptoms. I have brand new tires on it, + a recent front end alignment. The car is racking up the miles and this is just another wear item so I'm not feeling to stinky about it!
I'll let you know if it cured it.
/Eric
Ottawa, Ontario, Canada
'96 Mystique GS, ATX
Posts: 41 |
Checked all that stuff already. Tires are new all around. I believe these are the original wheel bearings. I think it's time to do them in any event.
-sp
