Posts: 663 |
Last night on my way home, I noticed my charging light flickering when I got into high rpm's(like 5500+), and would go away immediatly when I let off the acceleration.
Is this a sign of belt slippage or an early indicator of an alternator going kaput?????
Thanks, -Keith
Keith P.
Killed in action-4/27/06
'99 CSVT
#2369/2760-7/28/99
New Recruit-
1998 EO CSVT
# soon to come
Black 106,xxx
Posts: 6,910 |
chances are early sign of the alternator going but it wouldn't hurt to chang the belt, more so if it is old and see if that solves it
- 95 Mystique LS - Zetec/5spd
Posts: 97 |
Yeah, mine does that too, but I have a new belt on there....must be the alternator. Sweet.
Posts: 1,029 |
That's what mine did when it was going. IIRC, I had about two days until it died completely.
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 663 |
Keith P.
'99 CSVT
#2369/2760-7/28/99
New Recruit-
1998 EO CSVT
# soon to come
Black 106,xxx
Posts: 5,345 |
Originally posted by Manch-VegasSVT: Last night on my way home, I noticed my charging light flickering when I got into high rpm's(like 5500+), and would go away immediatly when I let off the acceleration.
Thanks,
-Keith
Belt slippage usually have an accompanying "squeeling" sound. Test the alternator after charging the battery well. And check the wiring (especially the ground which goes under the battery).
1996 V6 ATX 96K miles
Posts: 97 |
Originally posted by getsum111: That's what mine did when it was going. IIRC, I had about two days until it died completely.
Mine has now been doing it for two years. There is no squealing. Perhaps another cause?
Posts: 1,089 |
Originally posted by monsoon725: Originally posted by getsum111: That's what mine did when it was going. IIRC, I had about two days until it died completely.
mine too, just now for two years. but for as long as I've had, about 1 year now.
99 V6SE Sport ATX
Posts: 54 |
My bet is on the brushes being worn out. THat's what mine started to do. I left it too long before addressing and when I finally did ($10 part from Autozone), the commutator rings were wore out of round. New brush set lasted about one month, then light came on steady. One of teh new brushes has broke the wire attached. Poor little brush must have been bouncing like crazy. Chage the cheap brush holer ASAP and save the commutator rings.
Posts: 77 |
monsoon, didn't you have a topic last week about yours? I have had the same problem for 2 years now. New alternator, belt, battery, fuse link...same problem. checked the battery cables also...it's not that!!
