#1569218 05/11/06 01:12 PM
ok a few weeks ago i noticed that my car was acting funny. check engine light pops up and its the crankshaft position sensor. cool i went out and bought another one. well the problem got a little better but i still have the problem. car will rev in neutral at about 1,5-2k rpm and when it feels like it thats when it slowly drops down to normal, and whenever this is occuring and im shifiting gears the car idle stays up whereever i happen to change the gear at. please help me out some thanks.
#1569219 05/11/06 03:50 PM
If your crank sensor goes, your engine quits. Doubt it was bad. What was the actual code you pulled?
Idle speed is controlled by the IAC. They're notorious for gumming up and causing idle problems. Also, be on the lookout for vacuum leaks.
Steve
#1569220 05/11/06 04:05 PM
well the car would run fine for about 20mins and then after that it would start to do stupid things. when im at stop light and the car is in neutral the rev would stay high. and sometimes would it gradually come down and sometimes it just stays up. if im going slow the car would want to speed up by itself. if im changing gears the rev would stay high. pretty much where i would switch the gear at. i doubt its a vacume leak because it constantly do this but it doesnt do that. it only do it after 20 mins or so driving.well the guy from autozone pulled the code and told me it was the crankshaft position sensor and for a while i been waiting on a cel to come up and nothing. no check engine light so i dont know what to look for.
#1569221 05/11/06 08:21 PM
Originally posted by dremers vision:
...well the guy from autozone pulled the code and told me it was the crankshaft position sensor and for a while i been waiting on a cel to come up and nothing. no check engine light so i dont know what to look for.
Go to another Autozone or Advance and pull the code (s) again (even though it is not lighted, it probably has a intermittent code by now). Then post the code (s). I am surprised they did not suggest an O2 sensor. It seems that is what they suggest most of the time when a CEL code pops up.
#1569222 05/11/06 10:06 PM
W
W
The 02 would pop a P0420 code I think. That's what happened to me. I replaced the upstream 02 sensor and it hasn't come on since. Definately get it pulled for codes, maybe something will pop up. My car idles a bit high as well, but I have a Zetec. I just installed a 4 cyl. tach/cluster and not sure how accurate it is. But idle reads just a tad under 1k RPM's.
'96 Contour - Zetec/MTX 130+k mi. White/tan Tints, 2.25" custom magnaflow catback, tach cluster '86 Mustang SVO Red/Sunroof 80k orig. Needs work Cone filter, E6 Manifold, '01 16" Pony Wheels
#1569223 06/05/06 12:38 PM
O
O
my car is currently doing this as well. Did you ever figure it out? Thanks
Plain-jane 3.0L supercharged E0 FOR SALE OR TRADE FOR STOCK SVT PLUS CASH WTB- 36# return injectors
#1569224 06/08/06 02:58 AM
O
O
I replaced the TPS per Dremers Vision advice... fixed the problem, thanks.
FYI- The Murrays and Pep boys TPS sensor didn't work right, so I had to buy it at the Dealer ($52).
#1569225 06/08/06 03:20 AM
I had same problem, but was throwing CEL 122 TPS had them clear it, and came back on after 10miles. I took it off and it would not move freely by hand... After TPS replacement all is well.
JD a.k.a Fingers "Don't Panic" '98 Contour GL 2.0L VCT ATX 88k '98 Contour LX 2.5L MTX 120k Street racing can kill just less of a chance with a 2.0
#1569226 06/08/06 11:37 AM
Not sure if you are using a svt TB on your 3L but it has a different TPS that can only be had from the dealer so i read... CLICK
98.5 Black SVT with 34k miles Build #5683 Born on 4\15\1998 WR Headers GMK CAI Blaupunkt system fiberglass tweeter pods L.E.D. tail lights in the works
#1569227 06/14/06 04:33 PM
O
O
Well the new TPS worked great for about 1 week... Now mine is doing it again. Always at 2700 RPM.
When I come to a stop, it falls back down to idle.
