Posts: 1,356 |
Made a couple runs... The car ran a best of a 16.38 @83.8mph... I was pretty happy, best of last year was a 16.46 @85mph... Anyways, here's the timeslip results...  R/T 1.000  60ft. 2.43 330ft. 6.926 1/8 10.58 MPH 67.61 1000 13.71 1/4 16.38 MPH 83.81 Not bad for a V6 auto... Oh yea, mods are K&N Intake, optimized stock TB, SCT chip. The chip has the stock engine tune and a slightly more aggressive tranny tune... Thoughts on why my MPH was lower than before... Maybe time for some new plugs and wires?? I did do plugs about 30k ago... Wires are original...
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 2,086 |
Not bad for a slightly modded V6 ATX. I'm wonderin what the unmodded 4 banger ATX will do, I'd probably run around 18's or 19's.
Jason G.
Born: 11/96
Posts: 1,899 |
sun dial and a callander would work the best to measue time when dragging a stock zetec atx
probably around a 18.5-19
Posts: 235 |
Maybe temperature and humidity played a part in the different trap speeds. Pretty good for an ATX though. If the rain stops, my car will be done within the next week then I want to replace my IMRC box then attempt to break into 16's  . What tire pressures are you running? I'm thinking of running a higher pressure to maybe get some wheelspin to get the rpm's up and get it off the line better.
Metallic Steel Blue 99 SE Sport ATX
college= few mods
Infinity Kappas just added
I have no secondaries! SELL ME YOUR WORKING IMRC box!!!
Posts: 4,292 |
andy,was that with the 15's or 17's??
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 1,356 |
That was on the 15's... I think the car is gonna need some new wires soon... im still running the stock wires with 91k on the car... I ran the tire pressure at the max in the rear (44psi) and 42psi in the front... That was my best 60ft. time to date...  I was very happy with how the car ran... Time to get some exhaust work done and do some engine tuning and I should be close to 15's if not there... Thats what im hoping... It was probably 65-70 degrees with a fairly low humidity...
1999 Mystique LS V6
Posts: 7,117 |
I'm thinkin' intake cleaning/rebuild - if you haven't done one yet.
Posts: 9,196 |
I would've set the front tires to about 35 psi, try that next time but remember, no lower than that
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 503 |
I'm corious, how did you launch? Hold the brake and gas? And what RPM did you hold it until? Just wondering becuase after a big tune up and new Potenza 225/50 R16 tires I launch by flooring the brake and gas and drop the brake and its not even close to spinning the tires. Not even a squeak. So did you have wheel spin or no? Cause when I raced I got totally owned off the start and the car just bogs hardcore til 4500.
95 LX-with a mind of its own
24v DOHC
SVT exhaust and K&N=all thats worth modding
Go Fighting Sioux!!!
Posts: 451 |
its an atx its gonna be slow off the line. but i have 225 on and i can squeal tires off line and into second ( into second depends on the road)
2000 contour V6 ATX
BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
