#1568254 05/10/06 07:16 AM
Y
ymicz Offline OP
Y
'99 SilFro SE V6 MTX Alpine CDA-9833, 12" L7, Pioneer 6x8's, Fidanza Short Throw, K&N Drop-In, Spec1 Clutch/Flywheel, WR Headers / Y-Pipe, TBz Cat, PRT Roll Resistors Mods in queue: Trubendz Res. Magnaflow Ex. SVT UIM/LIM/Opt.TB
#1568255 05/10/06 07:35 AM
H
H
They look to be about the same as the ones I just got. You still have to dremel/file down the back side to actually make it fit in the 98+ fender hole.
#1568256 05/10/06 07:55 AM
Y
ymicz Offline OP
Y
ok, well im impatient, so i bought them, I'll report back with my findings.
#1568257 05/10/06 06:13 PM
Should work post pics once you get them.
#1568258 05/13/06 01:17 AM
Those are gonna look sweet...I always wanted to get the smoked ones and never did....
www.ChicagoCEG.com 2006 White Grand Prix
#1568259 05/13/06 01:55 AM
Now you just have to go to the dealer and get bulb sockets.Those won't have any as they are replacements for cars originally equipped with sidemarkers.
2000 Silver SVT
#1568260 05/20/06 07:25 AM
Y
ymicz Offline OP
Y
They are in fact the correct ones, now i just need the bulbs / sockets like you said. I will post pics of the whole process step by sep once i get everything. I got the rectifying diodes at radioshack but i need to find somewhere with 30ohm 20watt resistors.
#1568261 05/21/06 02:05 AM
I should rewrite the how-to. 5 watt resistors are adequate (industry standard 194 bulbs are ~3.8 watts). the ones you want are weatherproof sand-encased wire-wound resistors. two of these in parallel would work great:
http://www.radioshack.com/product/index.jsp?productId=2062292
50-ohm in parallel = 25 ohms (1/Rf = 1/R1 + 1/R2 + 1/R3...)
stack next to each other, wrap with a zip tie, twist the leads together, and proceed as normal. conveniently sold in a 2-pack too, one pack on each side and you're done.
E0 SVT, lightly modded
#1568262 05/21/06 04:16 AM
Those look to be the same one's I have. I really like them
98.5 T. Red Contour SVT Lowered on FSVT's http://www.cardomain.com/ride/2154233
