Posts: 197 |
does any one here from ontario know how the drive clean program will work if i were to swap in a 3L. i am currently looking to buy a 96 se mtx that i would be planing to eventually do a swap on... but how would that effect me passing the e test every 2 years... will i run into any problems.
RIP Frank Foreman. March 15 2005. died in a tragic car crash at the age of 18.<Drive Safe>
1995 Contour gl Zetec auto.
178000km
Posts: 2,974 |
There was one guy here that did the drive clean and passed fine. The way I see it you have two methods: 1) you can just say your car is a 2.5L V6 and your numbers will come out great because I'm pretty sure the newer 3L will burn alot cleaner then an older 2.5L or method #2) You can tell them and you can get "hotrod" status which means you don't do the drive clean because it's not an engine that came with the car but then I'm pretty sure insurance will have to be notified about the engine swap. I was told this stuff 3years ago so it may have changed now.
I personally would just go and tell them you have a 2.5L and see what the drive clean machine tells.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 375 |
Very interesting question, since i'll be in this boat come january.
if you retain the stock manifolds and percats you should pass with flying colours. but.. if you have headers or punched the precats, the single stock cat may not be enough to pass the test regardless of which engine is in there. (i do believe i've seen conflicting reports on this, but it's not like we're talking about the same tests as much of the available info here applies to the state that person happens to be living in, not what ontario say's it should be)
A possible solution for this could be to install a second converter immediately after the main stock one. (or two hi-flows if stock cat is not retained) I've been told that this will work, although have not seen if it does. My concern would be that the cat's are far anough back that they wouldn't reach their 'light off' temp, and then be nothing more than a restriction.
You've brought up a topic that i'm not too sure anyone in here has had to deal with yet.
Good Luck!
John.
96 LX 3.0L MTX - Black/Tan
K&N; 12lb F/W & uprated clutch
2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod;
UN-tuned Mod; 3rd Gear Synro-Crunch Mod
280K on the Shell, and 40ish on the Motor... 1/4 mile??
Yeah, it's a fun daily driver...
Posts: 785 |
another easier solution... just move in quebec
1998.5 Toreador Red/Midnight Blue Contour SVT - #5912/6535 - DOB - 05/11/1998 -
RU-3530/CTA Intake Pipe
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
SPEC Stage one/Spec Alum. Flywheel
HERE
Posts: 2,974 |
I would move there just so I wouldn't have to have a front plate  . Aaron
AKA NVS SVT
Yeah it's modded
Posts: 785 |
my svt is front ontario and im still wondering how im gonna get rid of the three stupid ugly licence plate hole on my front bumber...
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 2,974 |
I would switch front bumpers with you lol, but mine is rough shape  . My car is a US car that had no front plate.
Aaron
AKA NVS SVT
Yeah it's modded
Posts: 785 |
hehe no i will keep it for now.. but i will maybe make it repaint and try to make it fix someday... along with the little crack in the left side my svt rear bumber. Hum i wish i had money to repaint the whole thing
MSDS Heaser/Y-Pipe
Magnaflow #10435
9mm Ford racing
HERE
Posts: 2,974 |
HAHA I hear ya. My car is screaming for a paintjob it's in rough shape I cry when I see it.
Aaron
AKA NVS SVT
Yeah it's modded
Posts: 351 |
When I had My old 3L, I did it at a Ford Dealer. I told them it was a hotrod. I told them what I did to the motor and they where fine with that. It passed no problem. Just make sure you change your oil before you do the test...
ED
Black E0, 3L Hybrid. Long time ago...
It was fast. real fast...
