Posts: 19 |
im new to the SVT contour scene and i wanna do some light modding. i saw some forums about removing the resonator and i wanted to know if anyone could tell me the process...ive removed resonators off of cars that were connected to the airbox...but never one off an exhaust system, im just alittle worried about the size of pipe i should use to reconnect it. if anyone knows anything specific about this please help.
99 toreador red/tan SVT Contour Mirko Racing intake and splitter i sold my damn 5.0L for this car but i gotta say this car kicks my ass
Posts: 401 |
I just took mine to my local muffler shop- took him 10 minues costs about 15-20 bucks.
99 SE Sport 2.5 Duratec Spruce Green Metallic.. Aesthetic Only.... For Now
...the closest I will ever get to having a Turbo will be the Gillete Mach 3 variety!!!
Posts: 19 |
that would work...but me and my dad probobly wouldnt have too much trouble doing it.
Posts: 3,421 |
Well i will put it this way. If you do this you will get some droon. And if you decide that your gonna put some highflow mufflers in the rear it will droon/rasp like crazy. IMHO i would cut the rear mufflers off and put str8 pipes on there and finish it off with some nice tips. This way you will not get any droon or rasp. If you do decide your gonna cut your res take it with you and let me know, I know someone in the chicago section looking for the stock res.
Posts: 401 |
I don't mind the drone and my rasp goes away after the car warms up. but heard it is worse on an svt- i have an se. that is why I say take it to the muffler shop- they do dozens of custom jobs and can fix ya up so you have no drone and no rasp-I know people have done their exhaust and have no drone or rasp. there are mixed opinions. i know down here in Texas I have been told the res counts as a muffler- so your rear mufflers can be removed without worry of failing inspection. I would do a search in pics and vids and on exhaust and listen to what the differences are- then go with what you want to.
Posts: 2,848 |
it always rasps, but only if you're on it. I notice it when I hit about 4k RPM. After that the engine is louder, atleast from where I'm sitting...on the highway it's not noticeable...but anyway, performance first. It is louder that's for sure, I have set off car alarms. It also sounds bad@$$ ad idle FWIW.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 50 |
I had my resonator removed and when the Car first starts up on a cold morning(I live in Panama City florida , a cold morning is 65 degrees) The rasp is horrible Im looking for a way to get rid of it.. alot or people say it goes away when the engine warms up.. but i have driven from here to daytona, about 6 hours, pulled into my hotel gave it a little gas and the rasp was still there.. So i don't fall for the it goes away theory..not on my car at least
99 SVT with resonatorless exhaust and open element intake Sound System: Clarion touch Screen Source Unit Focal Components,Audiocontrol eq, eclipse Subs and Amps
Posts: 581 |
Hey Kev, Its kinda wierd......Here in Michigan it can get cold and when i warm up my car for a little bit....The rasp goes away......but if you want get a (not sure what they call it) but High Flow resonator.....Magnaflow has a good one for about 70ish or so .........Talk to Stazi......in the SeMichigan Forum.......
-Mancho- cars name is Connie 99 Silver Frost SVT #1986 k&n filter with cut out box true duals w/ flows  Ground Controls with 17's mille miglia ... Hightower headlights 15.4 at 90.29 at Milan dragway before the true duals
Posts: 1,537 |
You think 65 is COLD ??? You gotta come out here to NY.
Got my SVT Cat-Back done last fall. When I start it up on a 5 deg F day, it rasps for about 3 blocks. Then it is quite until I turn it off.
I have a slight drone which is loudest at 2000 - 2500 rpm. Driving on the highway isn't that bad as long as you are doing 60+ mph. Cruising at 50 mph puts the rpms in the 2000 rpm zone.
But once you get on it, BOOYYEEEEEE !! People look and say WTFWT ?!!?
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 3,421 |
Originally posted by coNNiethecoNTour: Hey Kev, Its kinda wierd......Here in Michigan it can get cold and when i warm up my car for a little bit....The rasp goes away......but if you want get a (not sure what they call it) but High Flow resonator.....Magnaflow has a good one for about 70ish or so .........Talk to Stazi......in the SeMichigan Forum....... Hey thanks for the heads up man. I will be talking to Stazi very soon.
