Posts: 97 |
Posts: 604 |
what did you do? just break the red off with a screw driver? you clean those up a lil bit they should look nice. if you decide sell those pm as i MIGHT be interested.
G/f's black 99se sport 5 speed
2 1/2 test pipe-custom cat back 3 single tip
cai with kn3530
safc optimized tb
8mm plug wires
spec stage 1 clutch
svt front bumper
Posts: 97 |
Originally posted by pimpdcontour: what did you do? just break the red off with a screw driver? you clean those up a lil bit they should look nice. if you decide sell those pm as i MIGHT be interested.
There done the easy part.
Now i have to straighten the rough edges and seal it and remove the rest of that red... and all i did was remove that red clear plastic. Looks really nice.... There's a 95% chance i'll sell it:), once i am done of course.
Posts: 9,872 |
I wanna see those on the car..clear tails with LED's would look hott!
Posts: 2,007 |
Cool.  I always knew there was a clear lense on the sides of the center reflector...but i never knew if it went to the center of the reflector...now we know! Looks pretty good so far, keep us updated...
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 4,292 |
i'm surprised you didnt know that!!!?!? i was tempted to do the middle piece when i did my clear corners...but i was in a rush so i just painted it black...good work..and no he didnt break the red off with a screw driver....its really really easy actually,just need a dremel with a seven dollar carbide cutoff wheel..the real small one so you dont go through the clear lense...took me all of ten minutes to do the corners lenses
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 2,007 |
i'm surprised you didnt know that!!!?!?...
When i did the clear tails, my reflector was already painted white at that time...so i never bothered really.
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 9,196 |
The clear tails look great on Amrav12's ride, but then again, his car is white and VERY clean and well modded
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 9,065 |
did you pop the merc badge out or did you cover it over!?
Posts: 9,196 |
Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢: did you pop the merc badge out or did you cover it over!?
I covered it over with this reflective decal I got at PepBoys, worked out great Just cut it down a bit and BAM!!!
"THEE" Roger R
USMondeo@aol.com
