Posts: 158 |
I just received an Xcal2 from ADC. Keith wants me to datalog various info, short term fuel trim, long term fuel trim...etc. Does anyone know what would constitute good data? Is there a specific way to drive so he has all necessary info. At this point with just a base tune, i really do not feel comfortable taking it anywhere near redline.
Oh yeah...it is turbo'd, t-28 kit.
Adam
-Adam-
2k Silver Frost #939 - 36K Miles
H&R + Koni + Mirko + Elky Mesh + Hella Optilux + K&N + LoTek + Mille Miglia EVO 17" + ADC T-28 Turbo + Magnaflow 3" S.S. + exhaust leaks + CEL light + more to come...
Posts: 1,943 |
do a pull with constant throttle in both open and closed loop modes. 3rd gear pull is good speed limit permitting...
the 3.0L
oval port 3.0L '98 midnight blue se
Posts: 9,065 |
Originally posted by 5speed3.0SE�®: do a pull with constant throttle in both open and closed loop modes. 3rd gear pull is good speed limit permitting...
Highway pulls are fun...I did that recently, but I forgot to turn off my governor...ownage.
Posts: 158 |
so by highway pull, are you saying, pick 3rd and slowly wind it all the way out??
-Adam-
Posts: 3,738 |
personally, when i need to data log i always use a good 3rd gear highway pull. i usually do it with 3 other people though lol. we get all mission impossible/james bond style and send one person to an on ramp before the one i will be driving up, send one person about 1/2 mile ahead (just before the next on ramp) and one other person in the car with me to hold the laptop. short shift 1st and 2nd on the on ramp and let it rip WOT all the way through third.
~Andrew
2001 VW Jetta Wolfsburg Edition
20 valves of fury
Posts: 1,860 |
Find an out of the way street. Sit in neutral turn on the datalogger and rev the engine up in about 750 rpm increments. Should be about 6 reference points. This will show how to tune your idle and cruise. Then do a quick run through 1st and 2nd up to about 5k. If you have room get third. Turn off datalogger. You will be stunned how fast it will ramp up to 5k.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 158 |
Thank you guys for the input, I really appreciate it.
One clarifying question before I go out to "play". When taking the "quick" run through 1,2,3 taking the RPMs up to 5000, what type of throttle should I be using? Wide open? Steady acceleration? If less than WOT, what percentage is suggested?
Adam
-Adam-
Posts: 5,810 |
You need to do both. At idle, at light cruise in 3rd gear, and then a 3rd gear pull from a lower rpm. During your light cruise datalog runs, pick rpms that are easy, such as 2000, 2500, 3000, 4000 rpm so that you have several runs that represent different airflows and thottlepositions. Then the full throttle run from say 1500 all the way to redline in 3rd gear will show how the fuel system is metering in WOT mode. The cruise runs will show how your O2 sensors are working along with your MAF and of course the fuel trims will help determine how closely the tune is matched.
See My Mods
