Posts: 60 |
From searching, it seems like most people suggest the MAF adapter and a k&n RU-3530 filter. I ordered the filter, but can't see spending 40 bucks on that piece of aluminum. I want to make my own. Anyone know the dimension on this (bolt spacing, diameter, flange ID, flange OD) so I can make a CAD model. I plan on machine it at school, Just didnt know if anyone knew the dimensions.
thanks, Jeff
00 SVT #985
Silver Frost
89 Mustang GT TT
-410.6hp/460.7trq (couldnt pull past 5k-lean)
12.77 @106 Before turbos, 12.82 @120.12 With them
-95 Contour GL, 140K FREE!
-WPI FSAE 05'-06', build a race car, get school credit
Posts: 1,029 |
If you can wait till Sat. I can PM the dimensions to you. Won't have dimensions till then. But you might be able to get them off the MAF gasket, as well.
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Posts: 60 |
I can measure the MAF itself to get the bolt spacing and a general idea about the size itself, but as far as the flange where the filter slips onto, i was a little confused about. According to the websites that sell the adapter, it fits any airfilter with an 85mm ID. According to K&N's website, it has a 95mm id, but thats the part number everyone suggests. You don't have to go out of your way, I was only asking if anyone actually knew.
Jeff
00 SVT #985
Silver Frost
89 Mustang GT TT
Posts: 1,029 |
That could be right, since we have to REALLY crank down the K&N so it fits tight. Might be 10mm worth. Let me know.
Scott
Posts: 3,637 |
check the Ru-1785 filter for the size, it fit over my Adapter snugly and was perfect.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 1,746 |
Yea FYI, on the RU-3###, the part where the clamp is needs to be tightened down like a bia...So, just take the measurements from the MAF and you'll be good.
2000 Contour SVT
SF - #542 of 2150
Posts: 299 |
OR...for an MAF adapter for about 26 bucks go to www.ssd4u.com ad ask for only the adapter and no hardware.
98' Black SVT
Build #1915 of 6535
Posts: 604 |
auto zone sells these for 12 bucks.. and in dif colors.
G/f's black 99se sport 5 speed
2 1/2 test pipe-custom cat back 3 single tip
cai with kn3530
safc optimized tb
8mm plug wires
spec stage 1 clutch
svt front bumper
Posts: 225 |
Unless auto zone has different ones from what I saw, I dont believe that it will work. I saw one there the other day and I am pretty sure that it is far too small overall. For 12 bucks that would be great if I am wrong though.
99 csvt
68 cuda fastback 340
00 gp gtp (wife)
01 gs500
Posts: 299 |
Originally posted by hot3dog3lucky3: OR...for an MAF adapter for about 26 bucks go to www.ssd4u.com ad ask for only the adapter and no hardware.
These are specifically made to fit the ru3530. The ones at autozone don't fit, unless they've gotten new ones since i last checked.
98' Black SVT
Build #1915 of 6535
