#116871 04/09/02 05:09 AM
Well, I noticed the heat soak when I installed the KKM, but thought it was a common side effect with the open air element. But, I just recently noted the discussions that have been had on the heat shield, and when I tried contact the custom heat shield guy in Colorado, his email didn't work. So, since I'm new to the CEG thing and moding my baby, (1) where can I get a custom heat shield, (2) how much power do I lose without it in extreme temp's (Houston summers get into the 100's easy), and (3) how often do we have to clean the S&B Power Stack so as to not compromise the engine (I've never oiled and cleaned it, and I've had it on for about 9 months since purchase)?
Any help would be great, since I've sifted through the archives and come up with contradictory, piece-meal suggestions. . .
'98 Black SVT #651 of 6535
KKM Intake (Miks Heat Shield in Winters/Drop-in K&N Summers), SHO Y-Pipe, and Bassani Exhaust.
Eibach Pro-Kit, Koni Struts, and Enkei RS5's with BFG-KDWs (215/45-ZR17)
BAER 13" big brake kit+rear baer rotors all zinc washed, cross-drilled and slotted (Greenstuff binding rears)
Kenwood head unit with Infinity reference speakers+1 8" Bazooka Tube fed by two MTX Blue Thunder amps.
Hella Stage II HIDS from hids4less.com.
Recaro Sport Seats trimmed in supple black leather.
And Zymol wax to keep it squeaky clean.
#116872 04/09/02 12:00 PM
Master P
Master P
John probably has a different email address than the one you found.. He just changed it a couple weeks ago. I'll drop him a line and let him know you were looking for him.
#116873 04/09/02 12:43 PM
Umm, who makes these heat shields? I would like to get one also!! Perry?
98 E0 Silver SVT
KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
#116874 04/09/02 02:22 PM
jcaimhigher...
check the CO-CEG forum
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
#116875 04/10/02 04:09 AM
I asked Lance to change my email info to reflect jcaimhigher@hotmail.com. Maybe he's been busy. I still have the hotmail email and my primary is jcaimhigher@ixpres.com.
John
#116876 04/11/02 03:12 AM
H
H
will the head shield fit other intakes or just the kkm
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#116877 04/11/02 04:25 AM
Nothing against jc-aimhigher, I may even buy his heat shield, but I thought of making my own useing plexiglass. I have a very large piece of smoked plexi but would it get to hot for it and melt. I have used plexi in a stereo install to cover the battery and fuse holders under the hood and it lasted until I took it out. If it is going to be to much trouble I may just buy one premade, but I thought it would be custom looking to build one out of plexi.
98 'tour silver
KKM
svt exhaust
svt wheels
stereo mods=kenwood head unit
alpine amps installed
12" kicker comp vr sub
purple calipers
www.angelfire.com/realm2/silverbullet/contour.html
http://members.sounddomain.com/silverbullet02
Mods to come!
purple neons
marker lights
PUTER chip
svt body kit
lowering job
PROBABLY IN THAT ORDER!
_ _ _ _ _ _ _ _ ___ _ _ _ _ _ _ _ _
