V
V
Mechanic in NYC area charging me $668 for following 50K tune-up:
air filter
fuel filter
spark plugs
ignition cable
PCV valve
oil change
coolant flush
injector flush
clean MAF sensor
check belts and hoses
inspect brakes and exhaust system
check intakes
his labor rate is 75 per hour. parts are 368 , labor is 262.
What do you think?
VincentNJ
air filter - maybe 20 or 40 for a K&N
fuel filter - 15 at walmart
spark plugs - about 30
ignition cable - whats this? if plug wires - 60
PCV valve - 10
oil change - 30
coolant flush - ? can't be to expensive
injector flush - average about 80 to 100?
clean MAF sensor - do it yourself
check belts and hoses - do it yourself
inspect brakes and exhaust system - do it yourself
check intakes - what does this mean
sounds somewhat high but I really don't know because I would do all of that myself
air filter
fuel filter
spark plugs
ignition cable
PCV valve
oil change
coolant flush
injector flush
clean MAF sensor
check intakes
What do you think?
VincentNJ
Yes, it is reasonable. Labor is usually the expenisve portion and it appears to be about 3.5 hours for all those items.
