Hydraulic lash isn't ideal for racing or really wild camshafts. About 8500 rpm the valves will start to float, which at that point there is a big chance of the valve hitting the piston tops then kaboom.
I used stock 3L lifters, relatively stock springs and stock 3L valves with steel seats. The ports were ported to 35/36mm spec which matched up to my PP 3L LIM. Stock 98.5 UIM and polished SVT TB.
While I wasn't really told the exact spec of the cams, they told me 20% more duration and less than 10MM of more lift.
** FYI **
I've come to the conclusion that the secondarys are actually a big restriction making this much N/A hp. This is due to them actually opening too slow and making that power dip in the power band much bigger than before.
In a stock SVT it?s just a small dip, but in a highly modified engine that revs much faster that dip is much bigger because they don't open faster to keep up with the fast reving engine.
If I manually keep them open or use a gutless LIM the power band is from 3-7K. Lotsa fun drag racing
If I let them open normally I have big torque at 2K rpm, 3K comes around and they start to open sapping out power. 4K comes around and they are finally open. Now my power band is from 4-7K. plain sux
If I manually keep them closed I get huge amounts of torque from 1-3K then it runs like an ol 2 valve GM motor. 2nd gear wheel spin is cool
I'm trying to develop a LIM that uses a HD electrical solenoid. This should yield a better mid range. Sorry for kinda getting off your topic
