Posts: 134 |
has anyone ever removed the screen in the mass air flow sensor, i removed the one out of my friends 95 s-10 ss and the differnce was unbelievable
Posts: 1,428 |
I believe this is a bad idea. The screen was put there to straighten the flow so that the MAF could get a reliable reading...
.. I don't think Ford would have put it there to purposely rob horsepower. I don't see how it could hurt either, unless it's all plugged up and full of lint??
Posts: 5,296 |
My car didn't come with one when I bought it... Someone must have taken it out.
Posts: 407 |
Have had mine out since I installed the 73mm MAF - any performance improvement I attributed to the MAF and not the lack of the screen, but ya never know??
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
Posts: 34 |
LBVSVT, what MAF do you have? THe C&L? if so are you getting problems with it running lean?
2000 Black SVT SHO y-pipe / hi-flow cat Large Cone Filter B&M shifter C&L 73 MAF Pro-Flow Optimizer Magnaflow Res BAT Intake Always looking forward to beating those coffee can wanna-be-fast imports. Douchebag Racing: You dont need a racing team and trailer for a 14 sec. car. Check it out: www.geocities.com/jcs9614
Posts: 2,915 |
ask JSMITH he was telling me one day how he put his screen back in and what a difference it made said without the screen he was losing HP because of turbulance these arent his exact words but im sure he will stop along sometime and voice himself
www.shox.com Dealer Koni's 135 a piece Eibach's 190 a set KYB's 70 a piece H+R's 225 a set see profile for website, aol name, etc Business:WestEndMobil@yahoo.com Personal:Corey_pimp1@yahoo.com 1998.5 SCSVT ($16000 takes it) 2001 GSXR-1000 1988 Corsica (the beater)
Posts: 1,071 |
My screen was taken out about 6 months after I bought the car when I installed the KKM. That was about 4 years ago.
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 2,112 |
Originally posted by AirKnight: My car didn't come with one when I bought it... Someone must have taken it out. The screen only comes on SVTs because it uses a conical filter.
Posts: 3,567 |
I also removed the screen from my MAF when I installed my KKM. I left it out becasue it was difficult to put back in, plus it was cold outside, I was puttting it on chrismass morning.
After noticing my car idling a little rough and a feeling of the power comming and going while under hard acceleration, which it never did before the KKM, I decided to put it back in.
It wasn't hard to do, especially since it was alot warmer, plus I heated it up with a hair dryer too to help soften the rubber.
With a little finessing and some fancy finger work I managed to get it to fit into the KKM's MAF adapter. Then it was a little bit of a struggle to get the rubber tube that mounts the filter to the adapter to go over the screen since the parts of the screen that extend outside th adapter are slightly larger than the OD of teh adapter. I found a little vasoline on the inside of the rubber connector helps it slide together nicley. (see, it has other uses)
Once installed my only raction was, OMG, why didn't I put it on in the first place. There was a very noticable increase in low end power and the top end power was now smoother and stronger, contrary to the belief that the screen creates a resistance.
If you don't believe me try it for yourself, I'm confident you will find the same thing to be true.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 650 |
Would this be worth trying to fabricate and put on a car that didn't come with a screen but now has a conical filter? Like mine?
Ohsigmachi '96 GL MTX Zetec SS (SuperSleeper) Suffice it to say my mod list has become so long that it is just ridiculous
