#1559639 04/27/06 05:18 PM
svtnics Offline OP
Bare with me the computer I'm using is too slow too keep searching for previous posts. I did find a couple that were exactly like what i'm having probs with. ok..... massive slipping from stand still start, irrratic shifts ( not sure what gear it wants to be in, bassically it seems like the trans main line pressure is all over the place. also the o/d light flashes. speedo works fine. from what i read it seems like vss, but, is it the two wire sensor behind the drivers wheel or the sensor below the exh. manifold right at the bellhousing? i checked the resistance of the one behind the drivers wheel and it was 170 ohms, and the vss spec is like 190-250. so...... what do i do? sorry, 1998 Mystique 2L Auto
export the imports
svtnics Offline OP
ok, cleaned all sensor connector pins and topped off fluid, which was almost a quart low(damn women). Test drove for 45 min with no problems. 2 days later my sis calls crying saying she was slowing down off freeway exit and she heard a lot of grinding and the car died. auto trans are my worst subject to diagnose, but it kinda sounds like the torque converter? the only thing i can see grinding other then the stator coming apart would be the pump, or the planetary gerset which i highly doubt. if anyone has anyexperience with a problem like this please help.
export the imports
Check the fluid level again. How is it? If fluid level is fine, what is the atx doing when you put it in gear?
Bob
