Bare with me the computer I'm using is too slow too keep searching for previous posts. I did find a couple that were exactly like what i'm having probs with. ok..... massive slipping from stand still start, irrratic shifts ( not sure what gear it wants to be in, bassically it seems like the trans main line pressure is all over the place. also the o/d light flashes. speedo works fine. from what i read it seems like vss, but, is it the two wire sensor behind the drivers wheel or the sensor below the exh. manifold right at the bellhousing? i checked the resistance of the one behind the drivers wheel and it was 170 ohms, and the vss spec is like 190-250. so...... what do i do? sorry, 1998 Mystique 2L Auto
