Posts: 33 |
Well after a huge deal of cleaning and doing some aestetics to my UIM. I finally got it back... well the guy who tried to powdercoat, then polish seemed to have broke off the bottem hardline (underneath the throttlebody) does anyone know how i can fix this??? it is almost broke off flush.
any ideas? anyone have to replace this?
Posts: 3,637 |
Junk yard should have the parts, I know Goonz replaced his about a mmonth ago when he broke his doing the UIM rebuild.
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
Posts: 33 |
Anyone know how he got it out???
I'll PM him also
Posts: 6,910 |
Originally posted by Tourige: Junk yard should have the parts, I know Goonz replaced his about a mmonth ago when he broke his doing the UIM rebuild.
i believe that was one of the vacuum lines on top of the UIM, sounds like this is in reference to the PVC line off the bottom of the UIM
- 95 Mystique LS - Zetec/5spd
Posts: 3,637 |
Originally posted by BrApple: Originally posted by Tourige: Junk yard should have the parts, I know Goonz replaced his about a mmonth ago when he broke his doing the UIM rebuild.
my bad, sorry.
230.2 WHP @ 6500
237.0 WTR @ 2250
Posts: 10,015 |
Drill it out and tap and thread in a regular brass 90�° threaded barb fitting.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 33 |
i'm not going to drill it out considering the tube is way harder than the aluminum intake... going to taper a pipe and get it in very tight.
Posts: 1,231 |
Originally posted by waubm: i'm not going to drill it out considering the tube is way harder than the aluminum intake... going to taper a pipe and get it in very tight.
If you go that route, be sure to seal it with some JB weld or similar. That could be one hell of a vacuum leak if it came loose.
-06 GTO Torrid Red/M6
-98 LS with BPU
-05 Honda Odyssey EX-L
mv .zig ..\for\great\.justice
Posts: 55 |
If you still have the UIM off can you try to push the broken part of the tube all the way through into the UIM then it can fall out through a larger hole.
1998 Contour SE V6 MTX-75
Mostly Stock
1986 Ranger V6 4X4, the only mod: weight reduction by rust.
Posts: 3,637 |
Originally posted by Son�¼s: Originally posted by waubm: i'm not going to drill it out considering the tube is way harder than the aluminum intake... going to taper a pipe and get it in very tight.
The car would stall right away, so you know when it will fail.
230.2 WHP @ 6500
237.0 WTR @ 2250
