Posts: 829 |
Originally posted by Princess Tong Po: Originally posted by CSVT#49: Originally posted by Tourgasm: "Iss decurashun, dass all jus decurashon"
Eat decurashun, that all just decurashon?
Or
It's just for decurashon, that's it and that's all?
So what the hell does decurashun mean?
decoration
~Andrew
WooWoo~
SVT Parts For Sale!PM Me.
2006 M6 Cyclone Gray GTO
1995 Mazda Protege Commuter Special
93 FXDWG Dyna Wide Glide
I'm A TROLL Now!~
Posts: 11 |
Are you sure that thing couldn't be re geared for better power/rpm match up. Last I checked those diesels were made for low rpm matchup well at least on the duramax diesel it is. I am not sure about the exhaust pressure relation is between gas and diesels are. I.e. do diesels flow the same amount of air at lower rpm as a gas motor?
Jimmy
Vehicle: Salvaged 98 Contour SVT
Why: It was cheaper then and I couldn't let her go to the compactor.
Posts: 7,025 |
Originally posted by batteredSVT: I.e. do diesels flow the same amount of air at lower rpm as a gas motor?
i would guess they would flow more cfm since they are larger displacement engines.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 7,025 |
Jim Hahn
Posts: 11 |
that was my thought exactly. Seriously guys, read that thread directed to turbomustangs.com. The idea is ingenious. I love the idea of simply halving the a/r. Bigger housings for more fun. This could be the biggest gains in forced induction with a little R&D from people with the money talent and experience in this stuff. The idea of having a control valve on the blocked inlet to continually gain power and relieve back pressure is phenominal. I'd say go all out technical on this and get a computer driven module that would allow you to make adjustments on the fly to the valve for different conditions and different needs (i.e. who you're gonna smoke some honda or a viper) Go for it man and post some results. I am all into this one.
Jimmy
Posts: 2,097 |
How about one of those cutout controls? Of course you'd have to make it to withstand extreme heat...???
98 E0 SVT with some stuff
Posts: 1,084 |
Originally posted by stilov: How about one of those cutout controls? Of course you'd have to make it to withstand extreme heat...???
It is all discussed in the thread I linked to. None of those cutout things can withstand 1200 degree exhaust gas temperatures. Someone will have to try something else.
Fifteen men on a dead man's chest...
Maverick Machineworks is open for business!! Tell me what you need and I can make it!
Posts: 432 |
i think the turbo will work, is it exactly what you want for your tour , no . with as much air as a diesel flows, it might be a little sluggish during acceleration, that isnt really big turbo for a CAT so itll be better than a 12l one. make is a VG turbo look how durmax and international is doing it
Posts: 432 |
i do have a turbo program that i got from my diesel teacher a couple sessions ago ill try and get it uploaded
Posts: 1,084 |
Originally posted by SvtEdwardo420: i think the turbo will work, is it exactly what you want for your tour , no . with as much air as a diesel flows, it might be a little sluggish during acceleration, that isnt really big turbo for a CAT so itll be better than a 12l one. make is a VG turbo look how durmax and international is doing it
That turbo will be WAY too big for the Contour. He is thinking about putting it on his Camaro.
