Ok, I know there have been a few threads on this topic... but has anyone built one with a motorcycle engine?
This is still in the pipe dream/feasibility stage but here's the scoop:
My friend and I have been talking about building a go-kart/dune buggy "vehicle" utilizing an engine anywhere from 125cc-400. The plan is fab our own frame (maybe one from a catalogue). We would like to keep everything around $1000. I have a MIG welder and oxy-act. torch as well as almost a full garage of other tools needed. There is also the possibility of making it street legal but I have to look into the requirements for that.
I do have some questions on the feasbility of this project:
1.) If we build a frame ourselves it will be either aluminum or steel. I know aluminum is kind of expensive(have to check local prices) but I'm not sure if aluminum is able to be MIG welded, and I am under the impression that you need to TIG weld it. The lack of TIG welding equipment means we would use steel. Would it weigh down the vehicle too much to use a steel frame?
2.) Fabbing up a suspension, steering and brake system brings up another issue. Suspension is one of the areas I lack knowledge in. I would like the vehicle to be able to go offroad over fields and such but not to an extreme degree. I'm guessing the arms and pieces would need to be built from scratch. Would it be easier to use the suspension/steering/brake components off of a small car (Festiva)?
My school allows senior engineers to build cars similar to what I would like to build. They build an open wheel F1 style car. The one I saw used a 600cc engine along with sequential shifting. They limit the air intake to 20mm. Other schools along with mine hold a contest where the test all the cars to see who's is the best.
I'm going to contact the engineering deptartment, to see if I can get info on how the students build them.
I am aware of the great deal of research still needing to be done but the CEG community holds a vast amount of knowledge. Any kind of information is helpful. Please no flamers.
Thanks!
EDIT: I just remembered there was a vehicle similar to the one I would like to make on Junkyard Wars a few years ago. I think they fabbed a steel frame (not entirely sure), I know they used the powertrain from a 'bike. The theme for the episode was dragsters or drag racing or something along those lines. One team built a small lightweight vehicle which was the winner, the other built a large, heavy vehicle and I think it was powered by a 305 from an Olds. Just thought I'd mention all that.
