#116455 03/31/02 06:48 AM
I have an opportunity to purchase a rebuilt V6 SHO Taurus engine complete with computer. This is from a long time friend who's life is speed. He tells me that the engine would "bolt in" to my Contour.
Does anyone have any thoughts on this or whether is ability to "bolt in" would not just apply to the motor mounts but also the drive train.
Patrick
'98 V6 ATX GL Pacific Green Contour
'96 4C ATX GL Performance White Contour
'93 V8 351 F150.5
'68 Fiat 850 Sport Spider (In Peices)
#116456 03/31/02 07:02 AM
Almost positive it won't work. I thought the only Taurus engines that "bolted in" to our cars were ones that were like 98 and up.
#116457 03/31/02 06:57 PM
Nothing is compatible with our cars.
Tranny, mounts, axles, harnesses, PCM, etc...
2000 SVT #674 - Check it out!
#116458 03/31/02 07:37 PM
Administrator
Administrator
the major problem is that the SHO motor is too wide for the contour frame rails, making it a MAJOR structural deal to get it to even fit in there, even before you hook everything up.
It's all about balance.
bcphillips@peoplepc.com
#116459 03/31/02 09:38 PM
E
E
You should buy it and put it in a Festiva though!
Build yourself a Shogun! I don't have any pics or the link, but I am sure somebody does. smile
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
#116460 03/31/02 11:10 PM
H
H
Shoguns where the SHO V8- not the V6
'98 SVT #2253
Currently DEAD!
Cobra Paradise
#116461 03/31/02 11:25 PM
0
0
Shoguns that I've seen have had a supercharged V6 in them, Very fast. I think Jay Leno,sp? has one with the V6.
Would be fun to stuff one in a Tour though smile
Mark
00 svt tour- K/N filter, SHO SHOP Y pipe, 2 1/2" back to rear Y, improved tunes.
91 sho- Hi flow Y pipe, 2 1/2" exhaust, edlebrock rpm series 2 1/2" muffs, modified intake, K/N filter, modified manifold, 190 lph fuel pump, magnacor wires, ford double platinum plugs, underdrive pullies, custom LPM, 8 pound aluminum flywheel, hi revs race duel diaphragm kevlar clutch, solid torque limiters, poly bushings evrywhere, heavy duty subframe bushings, heavy duty engine and trans mounts, subframe connectors, front and rear strut tower braces, eibach springs, tokico struts, camber ajustment plates, light weight swaybar end links, cross drilled rotors, carbon fiber pads, 225/55/16 SP 5000's, redline water weter, redline trans fluid, mobil 1 synthetic oil, police grill and the need for speed!!!
It's a chronic disease.
#116462 03/31/02 11:28 PM
Master P
Master P
#116463 04/01/02 07:20 PM
HAHAHHAH imagine the face of some rich ******* when you smoke his/her exotic in a sprayed shogun festiva!
on a side note, why do u guys talk about putting "slightly" more powerful engines in this car? why do all that work for an extra 20hp at the crank? talk about a 351W project, then u will raise eyebrows wink
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
#116464 04/03/02 05:06 AM
220hp /200 ftlbs, that's about 35 ftlbs or the 3.2 @ 220/215. Tho the mighty Yamaha will NOT fit into the contour. As stated the SHOgun is the V6 Yamaha, not the 3.4L V8. IIRC no SHOguns were s/ced. Tho Jay Leno's has the bottle on it....
Ryan
98.5 Silver Frost Tour SVT 5979/6535
Born: May 15, 1998
Some Mods, still not fast enough..
90 Black SHO
SVT Performance.Com
