#1556525 04/24/06 12:33 AM
BOUCH96 Offline OP
Can someone please help me out. I have a 96 2.0 and Im tring to figure out were the pvc valve is on motor. Autozone guy told me it connects into the valve cover but the only thing i can find is the vac hose that goes to the air box. I also found a small hose that connects to something under the battery. I cannot find anything that this connests to. Is the pvc valve supposed to go some where in between these two hoses and someone just never replaced ti in the right area?
Youngest Retirey Ever
#1556526 04/24/06 12:35 AM
#1556527 04/24/06 12:37 AM
#1556528 04/24/06 01:20 AM
BOUCH96 Offline OP
thanks for the info, you wouldnt possibly know what that little hoce is coming from under the battery is. I thought maybe it was to a charcol box but I really have no idea.
#1556529 04/24/06 01:30 AM
I think it is the vent tube for the tranny.
#1556530 04/24/06 01:32 AM
BOUCH96 Offline OP
So is it ok to have that hanging or is there something that it connects to.
Thanks
Chris
#1556531 04/24/06 01:41 AM
I think the OEM batteries had a clip behind it. You just have to find a place to put it so that it doesn't get compressed.
Read this post to confirm if it is the same tube you are talking about.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1019364&Forum=trouble&Words=have%20to%20agree&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=1019330&Search=true#Post1019364
#1556532 04/24/06 01:46 AM
BOUCH96 Offline OP
Thanks youve helped me more than you know. I was about to start pulling this thing apart to figure out were it goes and that would have been fun now knowing that it doesnt go anywere. Thanks again
