Does anyone know what kind of gains this would do for an non-SVT Duratec?? I was wanting to know if I could justify the price. Also, I see BAT offers the lower intake manifolds for an SVT but does not have the upper. Have they run out??
2000 Contour 2.5L ATX (Medium Steel Blue)
Items for Sale
  • SVT Indiglo Guages (NEW)
  • Traction Control/Rear Defrost Switch (NEW)
  • V6 Speedometer/Guage Cluster w/ Tach (51k miles)
Josh, I belive cawong11 dynod a 5hp gain by putting the '00 (or was it '99) UIM and LIM in his '98 SVT. So, if you put a set of '99 or up UIM/LIM on your SE, I'd imagine even better numbers at the dyno.
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
I'm considering doing the U&L's as well for my 98se. Depends on what i put down after doing the headers, throttle body, and possibly the MAF. I can't seem to locate a set though. I found one set in the forums, but my refund hadn't hit yet and i had to pass.
I think BAT did sell out. You may call them and see if they are getting anymore.
98 SE
BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B.
====OnOrder====
svt uppers and lowers,
Or you can Extrude Hone your stock upper to beyond even SVT spec and install a SVT lower to boot...You like that idea, email me Silverbulitt@msn.com wink
Performance Xpress Racing
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
I've done mine, I got an upper from a wreckers and the lower from BAT. I already had the SVT throttle body fitted to my stock intakes. The Lower made more of a difference than the upper alone, have not got dyno figures though...
5 Dr, 2.5 V6 Ghia X, 1999
Modifications:-
Inventor of the inductive Secondary monitor
Chrome grill
JR cone air filter
Black Diamond cross-drilled & grooved discs with Predator pads,
ST200 throttle body, upper and lower extrude-honed intake manifolds
Scorpion s/steel exhaust
Current Project.. Building a ST200 powered MKI
paullorman@btopenworld.com
