#1555922 04/22/06 06:14 AM
my 96 se v6 just had a new alt put in about 2 months ago cars had about 400km put on it since .
batt light stays on , yet the car idles fine starts fine every time . but when i give it even a little the car stutters and stumbles .
as well as my head lights flicker a bit ..
my battery holds a charge i put a trickle charger on it and it chraged rite up and the batt light was still on .
yet when i hook up a volt meter to the batt the voltage goes down when i start the car ..
any ideas ?
thanks
96 sport 5spd = mild modd 2003 Nissan 350z track pack vortch S/C 467rwhp http://www.cardomain.com/id/tsidsm
#1555923 04/22/06 09:43 AM
Don't forget to check the inline maxi-fuse between the battery and the alternator. It is back against the firewall. On the V6 you need to pull the coil pack for access.
A fully changed batter (with surface charge removed) should read close to 12.5 volts with the engine off. With the engine running you should see something over 14 volts, ideally with a fully chaged battery and the engine reved up to about 2000 rpm with no electrical accessories on you should see 14.2 volts.
You may have a defective new alternator.
