Posts: 1,050 |
Yeah, that is why I recommend re-installing the heat shielding as I did on my own.
warmonger
You can call me anything you like as long as it's nice.(all lies accepted) 99 Silver Frost SVT. #226 of 2760 Engine: 3.0 power! Unique Stuff: Sunroof control module (#1 of 9) Car Audio: Loaded and loud! Check them out at http://home.earthlink.net/~twilson1726
Posts: 1,028 |
Believe Terry and Warmonger, my oil is about 250 when I let the revs run about 4-5k, sustained. not good. I have a custom Y-pipe without the heat shielding. Even when the ambient temp is in the 30s, I'm hitting 250ish!  Now, I need to get an aftermarket air to oil cooler. Be careful and reuse that shielding!
Chris NJ 98.5 SVT Silver Frost w/Frankentrans carsla AT optonline DOT net
Posts: 852 |
Chris, I'd try thermal wrap tape first... But then again you did not take the easy way out on your car up to date...
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 306 |
Does this mean that the SHO Y Pipe is likely to cause overheating oil? Can the heat from the Y pipe effect the temp of the oil in the sump?
Posts: 20 |
With all the posts before about custom and aftermarket y pipes, this is the first time I have heard anything regarding heat problems, although it makes sense. Thanks for the heads up.
2000 T-Red SVT, #562/2150 K&N w/heatshield
Posts: 1,050 |
Originally posted by Paul from the UK: Does this mean that the SHO Y Pipe is likely to cause overheating oil? Can the heat from the Y pipe effect the temp of the oil in the sump? Bingo! That exhaust in the y-pipe is probably 600 C at least under full throttle, and it is only an inch or two away from the pan. warmonger
Posts: 306 |
Damn,
I was going to re-fit my SHO Y pipe this weekend, I'll have to think again.......
Presumably, this problem also applies to the MSDS header & Y pipe set up?
Posts: 5,805 |
The stock Y pipe is insulated for that reason,early tests on CDW showed high oil temps but as most pople wont fit an oill temp gage or fit it in the wrong place, they never know,50% of this engines cooling is via the oil.The Modine style cooler is not enough when you mod the motor,in the worse case an oil/air extra cooler is needed with an oilstat.....
Posts: 4,319 |
Originally posted by AirKnight: $65?!?!?!?! I just paid $100 for a used modified Y-pipe! What does it matter, you are about to drop $400 on a y-pipe.....
1991 GVR4 Lots of mods done.
Posts: 1,701 |
If your modfying the stock Y pipe, you can leave about 90% of the heat shielding on. You only loose the part by the merge/180. The idea of using thermal wrap tape for exposed sections close to the oil pan sounds like a good idea. I think I just got a project for the weekend....
