The Bendix Ti's are AGGRESSIVE pads, that's why they brake so well.
The downside is some minor cosmetic scoring of the rotors in some instances due to rotor material hardness fluctuations and also pad material hardness fluctuations. The squealing should be addressed by either the shims or application of antisqueal "goop" to the back of the ads prior to installation (saomething you can also do after the initial install - just requires removing the pads applying the antisqueal and reinstalling them again).
