I've just bought an 00 SVTC with 110K mile on it. I've only filled it up twice so far and both times it has been very hard to fill. The first time I thought it may have been the gas pump as I had never been to that station before and it was a crummy place out in the boonies. Second time and the same thing happened so I assume it's the car. What happens is you put in the nozzle in the fill pipe and pull the handle, setting the latch to hold it open. After a couple of seconds, less than a gallon into an empty tank, it burps back, cut's out and would have covered me with gas had I not had the auto fill latch in place and stepped back. I then have to fill 'manual' just holding the grip very lightly so that gas trickles in. It take five minuets to fill in this way, and still cut's out 10 plus times. Several days after the first fill the CEL light came on, the only code is P0442, which I cleared. I have now filled up a second time (same slow process with cutting out) but it hasn't returned yet. I've searched this forum for P0442 and 'slow fill'. I've read all the posts on P0442 and found this post;
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=833701&Forum=trouble&Words=442&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=822663&Search=true#Post833701 which mentions cleaning out the evap canister of mud. I'll have a look tonight, but I assume that when 'FordLove' said he cleaned mud out he meant that he removed mud from the tray, not the inside of the canister. How does this help?. I found nothing under 'slow fill' when searching. I can see no damage to the fill pipe or connections. Does any one have any ideas? Could the carbon canister be blocked?
Thanks
Adrian Thompson
