Posts: 122 |
Just curious if anyone has recently paid to have a compressor repaired or replaced and would mind letting me know what I could expect to shell out to get it working on my 98 SVT?
Sucks but I gotta get it working..gonna be to hot a summer to not have air.
Posts: 888 |
had a 93 ford contour and the a/c went out about 6 yrs ago. the ford dealer charged me $1200 to replace the a/c system. the part (comp.) only cost about $240 at the time. they said it was for labor???? last year the a/c compressor went out on that same car... local repair shop wanted $800.00 to fix it by replacing the a/c comp. never got it done as the car was kinda getting old and had some trans. problems also... later it wss wipped out when the Hurricane flooded the car. it might not be the a/c compressor. it might be the bad wiring jobs on the ford contours, check to see if your car is under the 10 yr. 100,000 mile warranty.. for the defective wiring... go to the dealer and get them to check your vin. number in their computer.....they can let you know in about 5 minutes if its covered....
Posts: 5,143 |
Originally posted by dbird: had a 93 ford contour and the a/c went out about 6 yrs ago. the ford dealer charged me $1200 to replace the a/c system. the part (comp.) only cost about $240 at the time. they said it was for labor???? last year the a/c compressor went out on that same car... local repair shop wanted $800.00 to fix it by replacing the a/c comp. never got it done as the car was kinda getting old and had some trans. problems also... later it wss wipped out when the Hurricane flooded the car. it might not be the a/c compressor. it might be the bad wiring jobs on the ford contours, check to see if your car is under the 10 yr. 100,000 mile warranty.. for the defective wiring... go to the dealer and get them to check your vin. number in their computer.....they can let you know in about 5 minutes if its covered....
a 93 you say? was it a prototype or some sort, because last I knew the first year of the contour was 95... Unless you are speaking of the Mondeo, which first made an appearance in 93.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 21,197 |
A compressor is about $200. I had a guy do the work for $150 on my brothers '01 Cougar. I was lucky in that I sort of knew the guy so I got a break.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 122 |
Originally posted by Todd aRRRRRRRRR.: A compressor is about $200. I had a guy do the work for $150 on my brothers '01 Cougar. I was lucky in that I sort of knew the guy so I got a break.
Well I was hoping I could get that lucky but I will have to wait and see.
Thanks you guys!
