Posts: 82 |
I plan on installing 19# injectors on my 99 V6 MTX Cougar (return fuel system) and needed a bit of advice. Current performance mods are..
KKM SVT Intake SVT TB SVT Upper Intake Gutted Precats Borla Dual Catback
Someone made the suggestion of using the stock ECU and using Pro Flow's MAF calibrator ($120). What do you all think of this? Any drawbacks?
Posts: 7,329 |
Drawbacks.
yes.
The MAF optimizer is extremely limited on how it affects A/F at individual rpm points. It's also not extremely accurate (2 POT dials)
I would highly recommend the PRO-M 75mm MAF and an S-AFC to do it properly.
Stock ECU should be fine. Custom chip is always better, but not a requirement.
Posts: 68 |
I am doing this kind of setup right now with a C&L MAF and an Apexi. Although we tried it on another vehicle with no Apexi and it also appeared to work fine (ecu + MAF compensated and kept the long term/short term FT hovered around 0) but dyno data... only the butt dyno. It's fun to take a drive with the AutoTap and record what you can.
Posts: 351 |
I just bought 19# fuel injectors from bnoon. I will install them soon and see what the obd-2 reader says about my lean condition. I hope to go a little rich, say .93-.94.
No Apexi/Greddy, no 75mm Pro-M until I see a problem.
Let me know how you do.
98 Contour LX V6 Mtx
Posts: 139 |
Just out of curiosity, has anyone had about $2500 to throw into there car and tried any or all of these tasty items? Will any of them work on the tours? It seems to me that all of the actual engine parts should work since it's the same engine. I don't have that kind of dough so I guess this is for anyone that might have it (and would maybe want to sponsor me...  ). It does have some injectors on the page, since that is what this thread is about. Focus Cylinder Head (I'm going to keep trying this sponsorship thing until someone feels some sympathy for me  )
99 SE Zetec ATX CTA intake ZX2 FMS wires(that don't fit my oddball coil) andenthal@mindspring.com
Posts: 3,419 |
Originally posted by IndyTour: I just bought 19# fuel injectors from bnoon. I will install them soon and see what the obd-2 reader says about my lean condition. I hope to go a little rich, say .93-.94.
Let me know how you do. I hope it works out for you, but I don't think it will by just adding injectors. Have you ever checked your Long Term Fuel Trim values to see if they are extremely negative? AFAIK the PCM uses those when calculating pulse width at WOT (but doesn't update the values at WOT). The bigger injectors will definitely cause a very negative LT Trim, and if the LT Trim + the Short Term Trim is less than -30 (or more than +30), you'll throw a CEL. Means you'll need something to adjust anyway.
Posts: 351 |
My LT fuel trim runs from 18-30. My lean condition at WOT at the 02 sensor is 38%. I think its pretty bad. Enough to buy injectors.
Posts: 3,419 |
Wow, I knew you had a problem, but dayum that's a lot of Long Term Trim. I'm sure you'll let us know how it worked out. Good luck!
Posts: 316 |
PA 3L SVT,
You were right, CEL for LT Fuel trim -18 and ST -12. Code Rich Bank 1, Rich Bank 2.
Apexi, eManage, or Mafterburner in the plans, hopefully before SZ2002.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Administrator
Administrator
Posts: 5,037 |
Originally posted by IndyTour: My LT fuel trim runs from 18-30. My lean condition at WOT at the 02 sensor is 38%. I think its pretty bad. Enough to buy injectors. Have you checked your fuel pressure? Could be a bad pump or clogged filter.
