#1551351 04/17/06 02:40 PM
svtd00d Offline OP
hey all, im new here to contour.org, and already its helped me out with a bunch of stuff, thank you!!! but im hoping you could diagnose a small problem that im noticing.
('98 SVT 2.5L DOHC)
i recently did the throttle hang fix and that worked wonders, but i noticed a noise, sounds like a leak, when im moving slow and im in a high gear and i punch it. Im curious as to what this little sound is.
also, a constant almost screeching noise(that increases with throttle) is coming from the right side of my engine. It sounds like its coming from the pulleys, either idoler, or power steering.. i figure its from these becasue when i removed the belt, it was gone. If anyone knows anything please help me!!
-shaun
#1551352 04/17/06 02:45 PM
Welcome .
"i recently did the throttle hang fix and that worked wonders, but i noticed a noise, sounds like a leak, when im moving slow and im in a high gear and i punch it."
Check clamps and hoses for vacuum leaks.
"also, a constant almost screeching noise(that increases with throttle) is coming from the right side of my engine. It sounds like its coming from the pulleys, either idoler, or power steering.. i figure its from these becasue when i removed the belt, it was gone."
Belt screech? Check for worn belt. In addition, check that tensioner is within specs. There should be marks scribed on the cover.
#1551353 04/17/06 02:56 PM
svtd00d Offline OP
yea, i replaced the belt because i thought that was the problem originally, and while i had the old belt off, i turned it on, no noise, new belt on, same noise..
#1551354 04/17/06 02:58 PM
One other item to check, turn the a/c on and then off. To see if the a/c pulley/compressor is the problem.
