#115946 03/23/02 09:18 PM
When i first took the resonator out i thought it sounded ok, but when i put the sho-shop ypipe on its way too much drone and the rasp is just pissing me off. Can someone tell me how i can get rid of the rasp? Can i put a dynomax strait through muffler or a Dynomax turbo muffler in place of the resonator which one will work better? I just want to get rid of the rasp.
TIA
'98 S\/T
K.I.A 6/14/02
#115947 03/23/02 09:56 PM
Get the largest resonator you can get. I had the same set up and put a Brullen res in. It droned a bit sometimes but was way better. I've since gone back to the stock y, so there's no drone at all.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
#115948 03/23/02 11:53 PM
Moe Offline
I had a res-less SVT exhaust w/ a sho y-pipe and rasped till no end. I put my Bassani on and it was a little better, but after a wile I got tired of the rasp when cold and the drone at highway speeds.
I got the Magnaflow 14415 (I think that's the part #) from Anastazi, it was around $70 IIRC. I am soooo happy with the sound now. It's a little quieter at idle, doesn't rasp a bit, has much less drone, but still sounds like a Bassani when I'm on it hard. The Magnaflow is only 4" round, so clearence is no problem, and it's a straight through design, so you have nothing blocking the flow.
-- Mike (Moe)Lester --
98.5 SVT #5486
moesvt@comcast.net
Get your a$$ on IM and stop wasting bandwidth!!!!!!
#115949 03/25/02 08:24 PM
How long is that thing?
1998 Contour 2.5 Non-SVT (ATX)
SHO Y-Pipe
K&N Drop-in
#115950 03/25/02 09:12 PM
Magnaflow #10414, looks like it comes is 20" 24" and 28"
Time to order one of these
Scott
#115951 03/25/02 09:15 PM
Edelbrock 5503 $100 shipped to my door. Very nice sound!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
