#1550424 04/15/06 06:43 PM
Myrosia Offline OP
Hey guys,
I have a 1999 Ford Contour L4-122 2.0L DOHC SFI.
My struts need replacing because one in the back is leaking and making horrible noise over bumps and my ride has stiffened horribly. So bad, I get backaches driving my car now. It's like driving a truck without struts/shocks.
SO, should I have the dealer replace them or someone else. I want to make sure I get the best results that my ride softens.
Thanks
Mary
#1550425 04/15/06 07:02 PM
Call a few places & get QUOTES for the job. An 'estimate' will be a guess & the shop or dealer may decide to charge more if they have any difficulties. A quote will be a firm price for installed parts.
#1550426 04/15/06 08:48 PM
The rear struts were tough on my 95 Zetec. The top of the strut goes very high into the fender. Hard to get at. Replaced the springs as well. One was broken.
95 Contour GL. Bought new. BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids. Looking for 15" alloy rims-PM me. 180,500km's so far.
#1550427 04/15/06 11:29 PM
Myrosia Offline OP
Thanks for the reply.
I am still wondering:
1. Will the dealer OEM struts make the ride smoother?
2. Does it matter if I use OEM or after market?
3. What are ways to make the ride smoother?
#1550428 04/16/06 01:45 AM
F
F
The ride may not be smoother, but less shudder on a bump if your strut has worn out. Oem is best if you can get them at a good deal (Bill Jenkins Ford, Steve Tousley Ford). I have used Monroe Sensatrac struts on a Dodge with good results but you will need to replace both rear struts. You might need sway bar links or have a broken spring or bad mount. The easiest way to soften the ride is reduce tire pressure. If you have 35 psi, that's too hard, try 32 all around. Some tires naturally ride hard. The Contour is a "sporty" ride by nature, but not back hurting (at least not with the stock wheels.) [If you have 17-20 inch rims those will tend to ride hard ]
#1550429 04/16/06 02:18 PM
Myrosia Offline OP
Thanks. I guess I will stick with the dealer and install OEM struts...hopefully soften the ride. They said they charge $248.00 to install the rear sruts. I guess not a bad price for the dealer. Also, I was told, it's a lot of work to replace these struts.
In addition, I just got new tires last year,
Goodyear Assurance ComforTred P205/60R-15 90T VSB
and I keep them at 34 PSI as suggested. I want to keep them at the specific PSI so they wear evenly. Already I notice the front tires have a little ripple like on the outer ends of the them. I need to find out why that is happening. I paid good money for these tires.
#1550430 04/16/06 10:25 PM
F
F
It is a bit of a job, be prepared if it needs a new upper mount or a spring. 34 PSI might feel a little hard. If the front tires wear evenly at the outer edges, it's from cornering. Might be time for a tire rotation. If one edge wears more than the other the alignment is off.
#1550431 04/20/06 04:54 PM
Myrosia Offline OP
Hey FavoriteMystaque...you got it mistaken. I'm a girl no way would I install struts. I was saying, I think I will have the dealer install the OEM struts.
My initial inquire was....does is matter if I have the OEM installed at the dealer or have someobe else do it with after-market struts? I want the comfort and not have the ride so hard that my back aches from driving the car.
So, I am leaning towards the dealer installing them.
#1550432 04/20/06 08:20 PM
Like I said, get quotes. You'll get the best price & predictable service.
#1550433 04/20/06 08:36 PM
N
N
I have a full set of SVT struts that I am looking to sell if anyone is interested... 62K on em -- I simply swapped them when I bought the car, it rode nice but I didn't want to cut the stockies for the GC's I bought.
Crispy 99 Cougar - Arancio Atlas/Grey Graphite Pearl Custom Widebody 98 CSVT - Silver Frost #4014/6535 - Born 10/21/97 98 CSVT - Silver Frost #4085/6535 - Born 11/10/97 See My Rides
