Page 3 of 5 1 2 3 4 5
#1550123 04/21/06 01:08 AM
Thanks. Where exactly did you get the ST200 struts? Are they still available? I would love to see a pic of that setup. That is what I am looking for I think. I want to buy the suspension right now but can't find those struts anywhere. How is the alignment with that setup. Are you running the front camber kit?
#1550124 04/21/06 01:16 AM
Here is Allen's SVT:
I was thinking that you might like the H&R's.
Sorry Allen, I had my photobucket page up and remembered that I had one in there so I posted it. Hope ya don't mind.
#1550125 04/21/06 01:20 AM
It looks very nice. Any closer pics of that car. lol I still am searching for these struts.
#1550126 04/21/06 01:37 AM
I did a google search earlier and didn't find them either.
I found two more pictures of Allens ride that better shows the stance:
#1550127 04/21/06 02:37 AM
Thanks for posting a few pics , Christine . The "driving" pics are a couple of my favs .
I have a couple recent pics in THIS FOLDER .
I got the ST200's through BAT a few years back - was lucky , I guess . I figured I'd run 'em till I could afford Konis or whatever , then just never persued it any further (typical me ) . I'm not running any camber kits on the car & it never really affected tire wear a bit . I got 25,000+ miles out of my orig. stock tires & they never even needed re-balancing . IIRC , the fronts have almost 1.3�º of neg. camber & the rears are right at 1�º . I was doing quite a bit of autocrossing at the time I first did the spring swap , so the negative camber was OK for me . I've grown used to it since then .
~~~~~~~ Phil Black & Tan 2000 SVT Contour #2137 of 2150 35,000 miles & counting !
#1550128 04/21/06 03:06 AM
Thanks for the pics. The car looks good. I think bat still sells those struts but I see nothing about the 1" lower spring perch. I want my front a little lower. I found a 2 car that look how I want mine but I don't think the susp is made anymore. I have a link to the pages if you want to check it out.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=picsvids&Number=1195228&Forum=All_Forums&Words=1399&Match=Username&Searchpage=1&Limit=25&Old=allposts&Main=1195215&Search=true#Post1195228
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=picsvids&Number=1217226&page=&view=&sb=5&o=&fpart=1&vc=1
#1550129 04/21/06 05:12 PM
Mine too.
You should give BAT a call and see what they have to say about the struts, maybe they can still get them. Here is the number: 941-355-0005 or you can fax them at: 941-355-4683.
#1550130 04/21/06 08:41 PM
A few more pics for you guys. Thanks I guess I will try and call BAT and see what they say.
#1550131 04/21/06 09:00 PM
Hey thats me in one of those links!
Like we discussed, I dont think the BAT kit is going to give you the low enough look from body to ground, but it probably will from wheel-fender.... If that makes any sense
#1550132 04/21/06 09:09 PM
Yeah I get what your saying. I don't care about body to ground. I am more looking to get rid of wheel space if you get what I am saying.
