#115862 03/22/02 01:25 AM
SVT19 Offline OP
Does anybody have this intake and could you get the snorkle hose routed to the front grill because I just got mine today and I couldn't get all the fender panels back on. Personally I don't think it's worth the 160 dollars I paid for it.
'98 E0 Black SVT Contour
BAT Air Inlet Pipe w/ITG Filter
#115863 03/22/02 02:14 AM
N
N
nooooooooo don't say that!! I was just about to buy it!! back to the search engine to find another Intake..... maybe. i'll buy yours for 50 bux :p j/k
SVT EMBLEM MOD HERE
:::96:C:LX:::
Black 2.5L ATX "my beater" - Shaved ? badgeless ? SE rocker panels
:::99:SVT:C::: #2566 of 2760
T-RED/TAN "the bitçh" Brullen Cat-back w/ 3.5" angle-cut tips ? BAT European Suspension ? AFE Filter ? CnL 73mm MAF ? Diablosport Chip :MNQ3: ? Mirko front spilter ? Apexi SAFC (i'm scared to install! anyone in Norcal wanna help me?)
..::nyceboicreations.com::..
email:junkmail@nyceboicreations.com
#115864 03/22/02 02:49 AM
Mine showed up tonight. Along with the bat pipe. I didn't get around to hooking up the hose or the pipe as i didn't feel like jacking up the car and pulling off the wheel since i installed my catback last night.
I'll be getting around to it this weekend along with the APEXi SAFC. Just the filter alone made a huge difference on my car (since i still had the stock airbox and a pos paper filter and i did the catback last night).
98 SE
BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B.
====OnOrder====
svt uppers and lowers,
#115865 03/22/02 08:06 AM
MAF Adapter
K&N Conical (of YOUR choice - not stuck with someone elses choice)
~3" heating duct hose (3')
...easily under $100!!!
2000 SVT #674 - Check it out!
#115866 03/22/02 09:32 PM
If you pull the front wheel and remove the front/top 4 or 5 liner screws you should have plenty of room to get into the fenderwell area and find a good path for the hose. I trimmed about a 1/4" of sheet metal with a dremel to straighten the path and reduce any crunching of the hose when the fenderliner is put back on.
Scott
