Originally posted by Tim O.:
The codes I was told it was programmed to is the same as mine. Do you know what would happen if, let's say, the chip was programmed to a different car? I would think my car wouldn't start or run properly.
Tim
'00 SVT
Did you install it yourself?
You can tell you computer code by looking at the sticker that is partially hidden by the borttom retaining bracket of your PCM.
That code should match your program on the chip.
The car may very well start and simply run poorly.
Also, I think chips, in general, are pretty hit and miss.
