Ok. The trannie WILL NOT fit. The engine will with light modification. You may want to head over to the zetec maitenence for this one... The Trannie is considerably different, im assuming you have an automatic in your contour, in which case the only trannie you will be able to get in there if you want a 5 speed is the MTX-75 Rod Shift (95-97) contour trannie... That is without major modifcation. an ATX to MTX conversion takes a lot of parts, a lot of time, and a lot of money.
