#1546504 04/10/06 02:50 PM
lizard Offline OP
i just got my svt gauges installed with the faces from the group buy and i love it so much it is just really hard to adjust to different speedo. but other than that WOW!!! i will hopefully have pictures soon.
2000 contour V6 ATX BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
#1546505 04/10/06 03:03 PM
Glad you like them, lol
#1546506 04/10/06 04:28 PM
Yeah, you can't adjust the speedo because you bought the wrong gauges. If you read the original group buy when you bought them, you would know that.
Unless you have a 98.5-00 SVT gauge CLUSTER , not just the S&H overlays, you will not be able to make the speedo read correctly.
So did you or did you not buy the SVT cluster to go with the gauges?
#1546507 04/11/06 06:17 PM
lizard Offline OP
i have both the overlays and the cluster.
all im saying is it is hard to adjust to where the needle is. when the needle is straight up im used to it being at 70 on my old cluster instead of at 85 now. sorry for the confusion
#1546508 04/11/06 06:57 PM
You can't just plug an SVT cluster into a non SVT.
#1546509 04/11/06 07:33 PM
you can if you have a 98 and you use the 98 cluster or if you have a 99 or 00 you need a cluster from a 99 or 00
#1546510 04/11/06 07:54 PM
O rly?
#1546511 04/11/06 07:59 PM
so i drive a 99 se sport. if i got a cluster from a 99 svt it would work. or would i still have to ajust the speedo needle??
G/f's black 99se sport 5 speed 2 1/2 test pipe-custom cat back 3 single tip cai with kn3530 safc optimized tb 8mm plug wires spec stage 1 clutch svt front bumper
#1546512 04/12/06 10:50 AM
It would work fine. On my old '00 SE zetec I put in an SVT cluster and it was off all of 1 MPH...the tach, on the other hand....blah! No way that was close to accurate!
2000 Silver Frost SVT # 1637/2150 D.O.B. 01/14/2000
#1546513 04/12/06 12:42 PM
this was my case, all you have to do is drop the cluster in and it will work correctly, the speedo itself figures out what the speed should be based on the input from the vss/pcm
you might need to adjust the needle if someone else has messed with the guage already, I did because I set the milage to match my cluster, I used a OBDII scanner to set it and have tested that with gps
