Posts: 2,807 |
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 1,089 |
Wow there is alot of corrosion/rust around there. I bet your leak originates from a leaking rear valve cover or timing cover gasket. Clean the area good and after a week of driving check again and when you see a dirty spot from which you ahve already cleaned then that might be the origin.
Posts: 2,807 |
Yeah enough corrosion with the Canadian winters. It's an akward place to clean because it's only accessible from underneath but I guess I could try.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 2,807 |
Does anyone else have something to offer? I was hoping some of the resident experts would chime in.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 5,345 |
Originally posted by SVTCANUK: Does anyone else have something to offer? I was hoping some of the resident experts would chime in.
svttour gave you excellent advice.
1996 V6 ATX 96K miles
Posts: 2,807 |
I appreciate the excellent advice, my concern is that it is very difficult to see the source of the leak from below because of all the obstructions. I will try of course and report back.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 35 |
I am by no means an expert, but if the leak is really hard to find, you can always go with dye and a blacklight. They sell the dye at Kragen and you can get a blacklight anywhere...
-glenn
"Always workin to pay for the maintenance of my 'tour."
99 CSVT - Superchip, K&N Short Ram Intake, Pro Street 52" Blue Neons, Highs in Lows, Drilled/Slotted Rotors, Vortech SC is on the way...
