Page 2 of 2 1 2
#1544424 06/06/06 02:19 PM
O
OB1 Offline
O
I took these pics when I changed mine. I know its a little late but maybe they'll help.
I hads to pull a torx wrench apart to get the airbag cover off. There are 3 holes in the back of the wheel but only the center one has a bolt in it. You have to turn the wheel to get to it.
Pic of the torx
Pull the airbag cover
Thn unplug the airbag. Its the wire w/ the yellow sleeve there.
I didn't take anymore pics but after that it a snap. 1 bolt in the center of the wheel then it just slides off, you don't need a puller. Make sure your wheels are straight, I had to redo mine then just lift up & unplug the clockspring.
BTW these are just some supplemental pics to go w/ what Tony said, he gave the PC way to do it. I'm not going to post a bunch of warnings or whatever just use common sense & if you blow yourself up its your own fault!
Pic of the Clock spring
I don't "mod" I just fix what breaks! 98 CSVT #2527 T-Red (Limping) 98 CSVT #2228 T-Red (Donor) 98 SE Sport ATX V6 (Running again) If swimming is good for your figure, explain whales to me!
#1544425 06/09/06 02:22 PM
Thanks - not too late. I had to order the part since the only dealership around here that had it in stock wanted $66.86 for it. All of the others dealerships had it listed for $47.96, but not in stock.
#1544426 06/09/06 03:50 PM
TH says...
Airbag/clockspring...FYI...a few moths ago in a rural hospital emergency room, a tech was pronounced DOA.....He was working on a Ford car with an airbag (drivers side)...Waited 5 mins after power down before starting to remove the airbag.....with the bag off the wheel he disconnected the wire...The bag went off and slammed the back of his head against the body B pillar......DOA...reason...broken neck due to airbag impact.......Don't take any chances with these...they
will KILL you!
#1544427 06/09/06 08:00 PM
F
F
Originally posted by projectSHO89:
It's a small capacity. There's no need to be timid around it, but it does need to be respected.
Kind of an oxymoron don't you think? I respect things that can kill me enought to wait an aditional 9 minutes
Matter of fact, I removed mine last weekend and waited an entire 2 hours ... granted, that's because I was reinstalling the battery location in the trunk and rerunning all the cables and such, but still ... there is plenty to do to a car while you wait such a short time!
#1544428 06/09/06 09:07 PM
I wonder if the tech forgot to disconect BOTH the negative and positive terminals for the battery and did not put some insulators in between the cable and terminals to prevent accidental closing of the circuit.
From Ford CD Manual,
"1. WARNING: THE ELECTRICAL CIRCUIT NECESSARY FOR SYSTEM DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE POSITIVE BATTERY CABLE MUST BE DISCONNECTED PRIOR TO SERVICING OR REPLACING ANY SYSTEM COMPONENTS."
#1544429 06/12/06 03:02 PM
All's well that ends well. Disconnected the battery and waited a couple of hours. To remove the air bag, the two screws were T25 for my 97 Contour LX. After removing the 1 bolt in the center of the wheel. the wheel would not come off, it was stuck down by the clockspring. Pulled hard and it popped off with the clockspring opening up and shooting all over like a slinky. Used a body panel removal tool to pop the one yellow harness off the column. Put it all back together and no more flashing air bag light, and the horn works again so I can blast all of the idiots who like to cut people off. Thanks for all the help!
Page 2 of 2 1 2
