Redneck Troll
Redneck Troll
Posts: 2,621 |
Originally posted by JReebs96sport: This really should be stickied.
Agreed. Viola!
http://www.bnmotorsports.com
Posts: 512 |
Originally posted by bnoon: Originally posted by JReebs96sport: This really should be stickied.
Agreed. Viola!
Thank you!
For Sale - 96 Tour Sport 2.5L MTX with SVT Exhaust, pre 98 trunklid with newer Contour Sport spoiler instead of lip spoiler, newer Contour sport rims. Newer paint job. Brand new floor mats. Rust Free! PM me for details and pics.
Posts: 1,262 |
im thinking about getting a contour in the near future so I can be ready for the shootout at spring zing. this is great info.
Phil
Posts: 375 |
Originally posted by tod "choco vag" ras: Tap for knock sensor is M12x1.5. I drill it out with a 3/8 bit first and then tap the hole.
OK, i've a question here....
why is it a 'better' option to tap into the block when you could wire in the knock sensor from the 3L?? I spliced and soldered in the newer style knock sensor, as i felt this was easier, cheaper, and likely even more reliable then reusing the old part. It seemed to have worked for me anyway.
Anyone have any insight on this?
96 LX 3.0L MTX - Black/Tan
K&N; 12lb F/W & uprated clutch
2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod;
UN-tuned Mod; 3rd Gear Synro-Crunch Mod
280K on the Shell, and 40ish on the Motor... 1/4 mile??
Yeah, it's a fun daily driver...
Posts: 5,810 |
Beats me. I also wired in the new one since it is just a two wire sensor.
See My Mods
Posts: 10,015 |
Originally posted by warmonger: Beats me. I also wired in the new one since it is just a two wire sensor.
This is Todd's preference (tapping the block) - I too just rewire the plug.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,238 |
So if we port match the heads to the SVT LIM which fuel rail would bee needed? Still have to braze it or will the stock rail work? GReat info BTW Stazi. -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Posts: 1,978 |
From what I've read, using the svt lim and uim allows you to bolt on everything from the svt lim on up, including fuel rail, throttlebody / bracket etc.
Alex
'99 SVT Contour
Posts: 10,015 |
Originally posted by tropictour: So if we port match the heads to the SVT LIM which fuel rail would bee needed? Still have to braze it or will the stock rail work? GReat info BTW Stazi. -tropictour
Which do you think?? Seeing as you're port matching to use the SVT LIM wouldn't it makes sense that EVERYTHING on the LIM is retained?
AUSSIE ENDLINKS $70
Posts: 1,238 |
Just double checking. You know how it is the first time you do something. You want to try to have the least amount of hicups.  It will be going down this fall hopefully. Thanks again. -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
