Posts: 1,616 |
I'm not sure if that is exactly what they are called. Let me try to describe:
The black rubber strips at the top of the doors (your arm would rest on them with the window down) on the outside which contact the windows. They look like the pull off easily. Mine are coming off, and some sort of rot is making them bulge. Anyone replaced them? Easy...hard? Expensive?
TIA
Posts: 644 |
Originally posted by Mod-Deth: I'm not sure if that is exactly what they are called. Let me try to describe:
TIA
Very easy to replace (old ones slide out, new ones slide in), but pricey from the dealer.
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 1,616 |
Posts: 3,788 |
Do you have a U-Pull-It or junk yard in the area? Get some from there, much cheaper.
Posts: 777 |
I looked at ford parts online(from our links page, located under sp motorsports) clicked on brouse collision, clicked front door, then exterior trim. They call it a belt with strip. you can click on view image, and it is the one your talking about. they list it for $16.15 pretty cheap for brand new. hope this helps you out.
"we aren't punished for our sins, but by them"
2000 se sport tropic green/gray leather.
V6,svt body kit and E1 wheels/Avon tech m500 rubber, many mods.
2003 Eddie Bauer Explorer V8
2001 Suzuki Bandit 1200S
1996 Mercury Sable
Posts: 3,788 |
$16.15, that's not as bad as I thought it would be.
Posts: 1,616 |
Originally posted by skunk: I looked at ford parts online(from our links page, located under sp motorsports) clicked on brouse collision, clicked front door, then exterior trim. They call it a belt with strip. you can click on view image, and it is the one your talking about. they list it for $16.15 pretty cheap for brand new. hope this helps you out.
Thanks! Sure does...
Posts: 980 |
That's not it. It's the "Outer Panel Right" & "Outer Panel Left" pieces. They're b/ $55 & $60 IIRC.
2000 Mystique LS
Duratec 2.5L MTX
