#1543034 04/06/06 04:05 AM
JB1 Offline OP
can the front wheel bearings go bad and still pass the push/pull test? i ask because after replacing the axles (due to cv joints) and the front struts (they were in great need) i still have a strange sound that i believe can best be descibed thus:
Originally posted by stazi:
Does it sound like the buffeting you get like when you drive with just the rear window open on your car? If so it is probably the wheel bearing or maybe a tie rod is really worn (and dangerous).
i have been searching but it appears that no one has stated whether this can happen. my mechanic friend who is doing the work says that the bearings pass the push/pull test but they still sound bad to me when driving according to the descriptions i am reading here. btw, he said that the tie rods and other stuff appeared ok when he replaced the struts and axles. i also read ( i forget who stated it) that cupped tires may cause this as well. thanks
00 black/tan svt, #2052 of 2150, born 2/1/00 formerly known as my csvt "Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
#1543035 04/06/06 04:23 AM
Yes.. Bearings CAN pass the push/pull test at first. How long until they finally fail that test is a matter of driving style, climate and the actual way the bearing failed within the hub.
This isn't often, but to answer your question, they can.
#1543036 04/06/06 05:31 AM
JB1 Offline OP
thank you. atleast i know i am not losing my mind. more work is being done this weekend so i will just add the bearings to the list since i already have them.
#1543037 04/06/06 01:59 PM
smart move. If you are already "getting your hands dirty" you might as well fix the bearings.
