Wow... that fuse block is different! Has the little mini-blade fuses...
Mine has the larger blade fuses (probly like you have in the interior fuse box).
The missing "fuses" circled are actually relays like the yellow, black, and green ones.
Like mentioned, the relay socket with the metal jumper is for DRLs. The other one looks like it has no contacts, so there was never supposed to be a relay there.
