Page 1 of 3 1 2 3
#1540099 04/02/06 04:40 AM
im shure there have been numerous questions about this, but i cant find any posts that relate to my exact problem. ok so about 3 weeks ago i was driving and when i came to a stop the car stalld, i didnt really think much of it but then it did it again a minitue later. so i took the car to my shop and scannd for codes, it pulled up a imrc code, so i replaced the imrc 3 days ago thinking it would correct my problem, and still no go! now i know that i could clean the uim and the lim, but i was wondering if there was any other thing that could be going wrong? -thanx, chris-
99' silver smokin' csvt born on march 18 99' #1491 of 2760 burninrice no more
#1540100 04/02/06 04:44 AM
i imagine you've had the hood open, so this may not be your problem, but something similar happened to me, any time i laid off the throttle, it stalled.
check the big hose on the intake (idle air control, i think) and make sure it's connected. if not, that would cause a stall when the throttle plate is closed.
What do you mean, rhetorical question? 1998.5 SVT --> http://www.cardomain.com/ride/2155561/1 #4619 of 6535, born Feb 18, 1998. i'm a smarta$$, don't take it personally
#1540101 04/02/06 04:49 AM
that could be, but i have had the intake out a few times and it didnt seem like it was detatched at all. and at the same time the car doesnt stall every time i stop its intermittent
#1540102 04/02/06 07:26 PM
Originally posted by burninrice:
..., so i replaced the imrc 3 days ago thinking it would correct my problem, and still no go! now i know that i could clean the uim and the lim, but i was wondering if there was any other thing that could be going wrong? -thanx, chris-
Scan again and post the codes.
#1540103 04/03/06 06:30 PM
F
F
I had the same problem at one point as well. Replacing the IAC (Idle Air Controller) did the trick.
1998 Contour SVT Toreador Red/Midnight Blue 3090/6535 1999 Contour SVT Black/Prairie Tan 18/2760 1992 Dodge Stealth R/T TT Metallic Beige/Tan 1989 Chrysler Conquest TSi Red/Black Leather
#1540104 04/03/06 10:09 PM
what did that run you?
#1540105 04/04/06 08:13 AM
THe IAC run about 40$ around here. At Advanced. Mine has doen the same thing twice. I just havent replaced it yet, but it iwll be done this weekend.
Is yo idle alittle weird at times also?
98 Black SVT (4210/6535) 93 V6 Powered Protege
#1540106 04/04/06 07:17 PM
not that i have noticed, mostly just at a stop when the clutch is disengaged.
#1540107 04/05/06 04:31 PM
so i scand the cel again today and all i pulld up was a P0161 HO2OS heater circut fault, i replaced the fuse for the heated o2s about 3weeks ago and it hasnt blown again. i probably just have a bad connection/ground/or bad o2s on that, but that shouldnt cause it to stall unless the cat. is completly cloggd, but it is brand new, so i dont know. im not going to go in replacing parts untill i know for shure what is going on. and another thing, how can you tell which o2s is bad, because the scan tool at work didnt say wich bank it was and it should.....so confused
#1540108 04/05/06 04:56 PM
...P0161 HO2OS heater circut fault, ... .... how can you tell which o2s is bad, because the scan tool at work didnt say wich bank it was and it should.....so confused
P0161 = Bank 2 Lower O2 sensor.
On this 2-D picture, ignore the red box and arrow, the Bank 2 Lower is the sensor on the right of the pre-cat. The arrow is pointing to the Bank 2 pre-cat
Page 1 of 3 1 2 3
