Posts: 710 |
So how did they come from the factory? I'm a 2nd owner, and my top mounts were against the strut tower when I bought it... until a couple months ago.
morbid
2000 Contour SVT (black)
Posts: 10,015 |
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 644 |
Originally posted by Stazi: With a VERY slight gap.
Like this?
I am also concerned about this, and asked a similar question here.
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 10,015 |
Originally posted by delmar: Originally posted by Stazi: With a VERY slight gap.
Like this?
YES THAT IS NORMAL!
Read my previous posts as to why this is so.
AUSSIE ENDLINKS $70
Posts: 710 |
Stazi... so what if mine has a 1/4" gap? Is that still acceptable or is something wrong?
morbid
Posts: 10,015 |
Still OK, just means the rubber cones are wearing out and the strut assembly is slowly making it's way up. Eventually you'll need new struts mounts, but don't worry you're OK for quite a while.
AUSSIE ENDLINKS $70
Posts: 1,150 |
one of mine is the gap shown in the pic - i know that is acceptable but the 1/4 inch gap will induce clunking when the suspension is fully extended I ordered new cones for my suspension @$33 a piece just so that i can give myself piece of mind. I will have to disagree with you stazi, not to dispize you but to be on the safe side - it is not good to have a gap below your top cap on your suspension tower more than 1/8" FYI. Thank you though - JOE
Posts: 1,150 |
Like this?
p.s. that is like a 1/8" gap barely - you are fine, do not replace those yet.....
Posts: 10,015 |
Originally posted by blu_fuz: one of mine is the gap shown in the pic - i know that is acceptable but the 1/4 inch gap will induce clunking when the suspension is fully extended I ordered new cones for my suspension @$33 a piece just so that i can give myself piece of mind. I will have to disagree with you stazi, not to dispize you but to be on the safe side - it is not good to have a gap below your top cap on your suspension tower more than 1/8" FYI. Thank you though - JOE
Unless you're in the habit of taking jumps like the Dukes of Hazard you will NEVER fully exyend your struts.
AUSSIE ENDLINKS $70
Posts: 4,140 |
Just a technical detail - it's pretty easy to get the springs out of the seats with GCs. But I haven't had any alignment problems at all with that happening. In fact, it takes a good push to get the hats out of the tower when I adjust them for racing.
